Originally posted by spj
For some reason I just do not trust the push on fittings like Sea Tech. I have gone to crimp fittings. Off hand I do not know the brand name, I am at work, but I can check when I get home. They are a two part fitting, the fitting them selves, then a band that crimps around the pipe and the fitting. I get them at my local plumbing supply house. They are designed for Pex, but work with hose as well. I have not tried them on CPVC and do not think they will work. I have the old grey tubing that is not Pex, but they work just fine.
The down side is the crimp tool cost me about $95, and when I bought it I only need to do about 6 fittings. It was not easy spending the money up front, but it has been very handy, I have even used it with the 3/4" crimps to replace the ends on my fresh water hose, looks better then hose clamps.
Let me know if you want me to look up the brand.
