Seeking comments on this offer...
early traders had wood window frames subject to leaking, cant see on this one and screwed teak decking with same problem. Is that aft deck teak or something else. Those Cummins look neglected and will need some attention but they are great engines. the entire boat can use a lot of TLC and modernization but it looks a decent design. You really need to look under stuff in the bilge and stringers and tanks to see if it is worth the next step. Could be a nice boat with proper attention. No info on weight but the max speed claim may be a bit high. Run as a trawler it would probably give good results.
