Sewerage dumping
WALSHIE
Well-known member
This was a letter to the journal news:
http://www.lohud.com/article/20101208/OPINION/12080312/Raising-a-stink-over-river-dumps
I am the executive director of an environmental education center located in downtown Yonkers with a two-acre park, beach and restored marsh on the Hudson River. This is the third time the Department of Environmental Conservation has given Westchester County the approval to dump millions of gallons of semi-treated sewage waste into the Hudson in the past two years. We still have kids in waders in the Hudson River participating in seining classes, right next door to the pumping station that dumps this waste into the river. We never get any advance notification that they are going to dump these million gallons of semi-treated waste, about 100 yards in front of our restored area and where we have classes of children in the water. They usually do this in the middle of the night. Twice we have had to cancel classes at the last minute because we were not given prior notice of dumping.
The DEC always gives approval, but says it is the county's responsibility to warn people. The county spokespeople always say it is an emergency and didn't have adequate time. Each time they said they would do a better job of informing the public. For them to say beaches are closed and boaters are not usually on the river this time of the year is an absolute idiotic way of logically justifying what the county does once or twice every year. Let people know in advance or develop a better system of communicating with the public.
Cliff Schneider
Ahh, those wacky bureaucrats! Just make sure you don't dump your 20 gal. holding tank next to their sludge spill or they will give you a new meaning to the term "boating expenses".
In the Carolinas and Georgia LEO's are even jumping on transiting vessels to issue a summons if your holding tank seacock is not locked, even though closed. Can you say "revenue enhancement" boys and girls?
Safe and Happy Boating!
ColonyCove
Originally posted by Anchor Management
What is the "legal" definition for disabling your waste discharge system?
Good question I was always under the impression it needed to be locked or the handle needed to be removed.
I don't know that there is any clear cut definition. I've read that it has to be "locked or disabled" whatever that means...
Here is the official word:
When operating a vessel on a body of water where the discharge of treated or untreated sewage is prohibited, such as No Discharge Zones, the operator must secure the device in a manner that prevents any discharge. Some acceptable methods are:
Padlocking overboard discharge valves in the closed position, using a non-releasable wire tie to hold overboard discharge valves in the closed position.
Closing overboard discharge valves and removing the handle.
Locking the door, with padlock or key lock, to the space enclosing the toilets (for Type I, Type II only).
Lake Champlain has their own rules, they require you to actually remove any plumbing from your waste tank/macerator to your thru hull.
just to emphasize, the above applies to any location within 3NM of US shoreline.
if you get boarded and your Y Valve and/or macerator seacocks aren't secured as listed, you could get a fine.
i'm always amazed to see how many boats are not in compliance with this very simple and painless rule.
that description doesent account for the use of key lock on the overboard pump switch as is common on many systems.
That's what I have. I assume it's legal. But, is it?
While not specifically called out in the text I passed two inspections. IIRC one of the new systems using a key switch received written approval from the CG. The problem, as with all laws, will always be uneven enforcement by officials.
