I've used it for the past 3 seasons. After the initial adjustment, not a single drip from either shaft. GFO packing is as close as you can get to "zero maintenance".
Pascal makes a good point. I hadn't thought about that!
Been using it for several years and no more leaking. I've only been able to find it on line. I agree with Pascal. There have been a few catastrophic failures of dripless shaft seals. That won't happen with packing.
I can remove and replace shaft packing in about 10 minutes per side. I have a good packing extractor with fairly good access to the packing glands. I've done it on the hard and in the water also.
Brian, it depends on how much you use the boat and how fast your shafts spin... usually the GFO last longer. With the flexible corkscrew, you can indeed replace it pretty quickly (in water).
also, GFO doens't need any grease so it's less messy and easy to install
"doesn't need any grease"--correct. I spoke with W L Gore reps in St Louis and somewhere in Maryland. They both said do not add any grease. Using a rag and maybe a little cleaner wipe away any old grease and proceed. You needn't make a big deal of this. Just don't leave goobs of old crap . This is a very easy job and the kicker is you get such a great result.
Is there a step by step guide or pics anywhere that you guys are aware of? I'm getting steadily increasing drips from my shafts and rudder packing. Had these re-stuffed 2.5 years ago and put just over 4,000 miles on them.
Would like to do this maintenance myself, in the water.
