If alignment is within .003" and the prop scan showed ISO 1 or at least strong 2 and has very good balance, and cutlass is new, it does sound likely either the shaft could use straightening or the strut is a little loose, (...or the shaft is cracked). I'd imagine a loose strut would have been discovered during the recent cutlass replacement.
Without that wiggle, I'd 1st be checking for loose shaft ,rudder (and tab if any ) anodes and Spur bearing wear if you had those, & ruddder lack of 'toe" and shaft looseness, even bad motor mounts. Prop shafts with greater than normal spacing between strut and prop hub ( as needed with Spurs installation or somtimes just using available-length shafts) tend to amplify any slight prop imbalance, and are somewhat more likely to crack or bend shafts and wear cutlass bearings due to the extra leverage involved during prop strikes or perhaps even just from vertical stresses of running hard in heavy seas.
Some yards with good machine shops can check/staighten/ balance shafts. If you pull the shaft , check carefully for scoring to make sure it's worth straightening. Minor scoring can be polished out.
