"Can I continue to use the boat until haul out, or does this need repair now."
Yes.
At all levels, vibration accelerates wear to bearing and support structures. And you always have vibration, but under "normal operating conditions" it takes a very long time to wear out those surfaces. The more vibration you have, the more rapid the wear will occur.
SO, if the vibration is visible to the eye, I would guess that you have an above average ( well above average ) wear rate. So, yes you can operate, but it depends on how much damage you can tolerate. My tolerance is low, so I would not operate till the source is found and corrected ( and the resultant damage is repaired ).
