shifter control question- tilt/trim
Seagrace
What is the difference between a control that has trim switch only and a control that has tilt and trim switches?
Isn't it the same switch? For instance, on my OMC cobra shifter, I have a rocker switch in the handle that tilts the outdrive. The same switch trims the outdrive - but isn't it the same mechanism?
steve
