shoot through hull transducer
drfeno
Hi,
The boat I just purchased came with a Garmin 178C sounder. Older unit, but it still works great. The old owner never installed a transducer for it, so it is only a GPS at this point. I have the transom mounted transducer that came with the unit. Since the boat is now in the water, can I use the transom transducer as a shoot through hull transducer? This would only be temporary, as when the boat is pulled this fall, I would likely install a through hull for the unit. I'd just like the unit to be able to display depth. If I could do that, I'd move the older single purpose depth finder to the salon for the lower station. Any info would be great. Thanks
I recently installaed a Lowrance transom transducer as a through-hull. I found a good spot and glued it down with Marine Goop; which I expect will be a little easier to remove than RTV if I ever want to move it. Seems to work fine.
I don't think that will work. I have a new sounder with a shoot thru transducer. There is a base which is first glued down, similiar to a cup. The TD fits into this in a bath of oil. There can be no air between the base and the TD. In addition the hull has to be smooth (grinded and sanded)where it is to be mounted. If the hull is cored, you need to remove the top layer of glass, and the core, fill with epoxy and install the TD in that.
The base on my unit was formed on an angle so the TD can be installed level with various deadrise. You may be able to purchase a shoot thru transducer for that unit. I had an old Horizon thru hull which worked only when it wanted to. At first I was reluctant to go shoot thru, but I have had really good results with it.
The instruction manual for the Lowrance transducer recommended exactly what I did, however they said to use epoxy rather than the Marine Goop that I used. They did not require an oil bath nor any special surface preparation. My hull is solid, so I did not need to do anything other than glue it down.
I works fine in depths from a couple of feet to over 70 feet. If I decide to make it permanent I will replace the Marine Goop with epoxy.
drfeno,
I have a backup FF that has a a glued transducer into the hull. Works great but there's a couple of issues that need to be considered. Hull should be solid glass and the transducer should be placed in an area that is as flat as possible. If its on an angle then you will be shooting your signal at an angle and not vertically. This will give you false readings.
Perry
As MEIDE says it works just fine. I installed one a few years back and it works great.
Thanks all,
I'll give it a shot, I have nothing to lose as nothing will get damaged if I try it. I just don't know if my boat has a solid fiberglass bottom, or if its cored. I could call the guy at Silverton and ask.
drfeno - I have the 178C coupled to an Airmar P79 in-hull. It works great, but if you get good results by epoxying in the transom puck then I wouldn't change it. Just remember that the results may be a little skewed by the angle - more so the deeper you get.
Also note that the new puck might interfere with your existing DF - if that matters.
Shoot thru transducers are very sensitive to hull thickness and density. If you find the right spot, they will work but be prepared to move the unit around the hull to find the spot. I have heard that as many as 50% of those attempted do not work. Many marine electronics installers will not even try to install because the success rate is so low and the labor to find the right spot is so high. It can be cheaper to short haul the boat and install a thru-hull than playing around with a shoot-thru. Additionally, the end results will be better.
Mark
Thanks for all the info. I already have an older depth finder with a through-hull, so I can operate the boat safely. My intention is to see if I can make this work for basically the cost of a tube of Marine Goop and a little labor. It is not a permanent solution. I know that the sensitivity and accuracy won't be as good, but I'm really just looking to have a backup depth reading, or to be able to move the older unit to the salon so I can operate from down there if needed. I also spoke to the parts guy at silverton, and he says my hull is not cored, but solid fiberglass. When the boat is out this fall, I intend to install a through-hull for this unit. I'll post my results here. No guarantee that it will happen soon.
and that's what I use my shoot thru the hull for...strictly backup. Works fine.
I have installed 3 "shoot thru" transducers in boats with solid glass bottoms. 2 were for fishfinders, and 1 strictly a digital read out depth sounder. All worked just find, though the fishfinders both lost much of the sensitivity required to pick up fish, their bottom and depth readings were all perfect. One other tip I did pick up along the way was to use a slow curing epoxy when mounting the tranducers, not the fast cure. The reason being the fast cure epoxy sets up so quickly you can be left with air bubbles (created when mixxing the 2 parts) in the epoxy between the transducer and the hull, which could cause issues. The slow setting epoxy seemed to be a little 'thinner', and any bubbles have time to rise to the surface before the epoxy hardens. Using the slow curing epoxy also means ensuring the transducer doesnt move around while the 'puddle' of epoxy you have created and set it in hardens, so you probably wont want to use the boat for 12-24 hours (or what ever the epoxy requirers) after the install.
Terry
when i installed my gps ,i used a transom mount transducer and put it in a bag of water down in the bilge and was able to find just the right spot. worked fine in the bag till i glued it down. have to have a solid hull though.
bobt
I put a Garmin FF on my silverton now sold, i installed a garmin shoot through hull transducer it worked great and no new holes. I also saved on a haul out.
Thanks for all the input. I did install the transom mounted transducer as a shoot through hull, and I seem to get accurate depth readings. I just used marine silicone and stuck it to the inside of the hull on the flatest part I could find. The real issue was fishing the TD wire up to the flybridge. It seems to work well, we'll see how it stands up to use.
bobt
bobt:
Can you explain further? Not sure I understand how you did this. I just glued down my transducer, and now my readings are WAY off.
Ms Chrissy,
When you say the readings are way off...did they get deeper then the actual bottom? If so, then you glued the transducer to a not so flat (angled) surface and you are reading the bottom at an angle.
thoughts?
My depths will jump around from 15.7 ft to 775 ft, in waters that are no deeper then a couple hundred feet. My thoughts are that I did not glue it properly, hence the false readings.
It could also be that there is some turbulence on the outside of the hull right under the transducer. If you get air under the hull, it can cause false readings. Check to see if there is a through hull right ahead of the transducer, or a strake. Also, any kind of stepped hull will create a air pocket, if the 'ducer is aft of the step.
