I thought I'd put this in a new thread, the submerged shore power cord thread got me thinking that I need to make some changes to my boat. First some background, my '89 Sea Ray 300DA has the shore power connector locate on the port side about a third of the way foreward of the stern. The power panel is directly behind this. At my slip, I back in and that puts the power pedestal at the starboard corner of the transom. In order to get the cord to the inlet on the boat I have to attach it to the dock and run across the slip and down the finger and then into the connector. Very high tides(non floating docks) sometimes cause a long section of my cord to be underwater. I've never liked this and the other thread has prompted me to start thinking about a better solution. I'd like to relocate or install a second shore power connector on my transom on the starboard side so I can run a short cord from the pedestal to the boat without the problem of dipping the cord at high tides.
Now the question, can I install another inlet and run the cable to the power panel and still leave the old inlet in place (in case I need it at another dock)? Would a swithc be required? Is there a maximum distance from the panel to the inlet? Is there a requirement for any kind of breaker within a certain distance of a power inlet? I don't want to creat a new problem in solving the first one. I'd probablly have to increase the wire size running to the second inlet.
All you power gurus give me some advise, thanks.
Forgot to mention, boat is 30A no generator.
