You need a license from the Federal Communications Commission to operate on Amateur bands ( such as 2m and 10m ). In the process of getting the license, you will learn about 2m and 10m communications and why/how they are different.
While it is no longer necessary to learn Morse code for an amateur license, you -do- need to study and take a test. I have never met someone who was not able to learn what is needed, though the effort required to do so varied a bit.
The largest and most easily accessible source for such info is the ARRL ( Google it... ). They can lead you to learning materials, tests and other info.
Sailmail: Involves digital modes, discussed in the license material...
Handheld: It depends on what you want to do. This question is actually detailed, but self-answering once you understand the required material.
btw: I am not being short, or snippy, but all of these answers are part of the basic knowledge needed to be licensed, which -is- required. Once you have had a look at the study guide, you will have a better understanding, and you can ask more specific, answerable questions.
Enjoy, and good luck!
-- ( edit ) --
If you are reluctant to spend a few bucks on the study guide ( available at ARRL ), you might ask at the library for a copy of the ARRL technician's class study manual. It is quite possible they have it.
