If the shower floor can be drained above the waterline, why do I need a shower sump? That's the main question.
The reason for asking is that the shower sump in our old boat had a really noisy pump that nobody could forget to turn off. The sump was also below the waterline and HAD to be pumped or the shower wouldn't drain.
On the new/old boat we can't hear the sump. It will also drain into the bilge which aint good. But sometimes we all forget. I don't want a foul bilge and really don't want to burn up my sump pump.
Should I get a noiser sump pump? Are they rated in decibels? Is there a 110v switch which will burn a light that I can be reminded the pump is on.
The shower drain is above the waterline. Can I bypass the sump and let it drain naturally through the hull?
Suggestions?
Suggestions?
