sick radio
deltabighat
Being technicologically brain dead, I have a question. The marine radio on my boat, picks up transmissions from other vessels but cannot hear me. Is this a repairable situation or is it time for a new one. Are there possible fuse problems or other things to check. This one is a middle of the road Standard and is about 12 years old.
DBH
probably the microphone but you do realise that it is push to talk????
contact customer service at standard horizon for the nearest service center to you. have them bench test the radio. they can tell if its a radio problem or something like the antenna on your boat. if the cost to repair the radio is significant compared to a replacement unit or if your existing radio is not a MMSI/GPS radio i would replace it. you can also remove the antenna and have that bench tested as well. if there are fittings on the cable leading from the antenna to the radio, check those for corrosion as well.
If you can hear most likely the antenna is OK
What electronics in your home are 12 years old that you still rely on?
Buy a nice new radio and you will be happy you did.
Or it could be as simple as corrosion on connections to the mic; to the cable; to the antenna. The radio is usually the last thing to fail. My VHF is 16 years old and still works fine!
At 12 years in a moisture laden environment I would get a new radio and antenna. 12 years ago most radios were not sealed and able to withstand moisture that the new radios will. Did they even have the red emergency MMSI/location button? Antennas do not last forever. But if you need to find out if the boats that don't hear you hear a carrier with no voice or hear nothing. If it's no voice the microphone is your issue if they hear nothing it could be anything from the transmitter in the radio to the antenna unless you hear the other boats well then a simple return loss or VSWR/Power meter could help diagnose the problem. Bill
You could also borrow a hand held VHF marine unit and see if you hear your voice when you key the microphone. It's a start.
I had a similar problem with one of my ham radio mobile units. I could hear others but they couldn't hear me. All they heard was a clicking sound from the push to talk switch. It turned out to be a broken wire in the microphone plug at the radio. If you can hear others transmitting then the antenna is most likely OK. If you have a friend with a handheld radio or even a scanner, listen to yourself when you push the push to talk button. You should hear a clicking sound from the switch, If you hear that, press the push to talk button and talk into the microphone while moving the mike cable at the microphone and at the radio. It just might be a broken wire in the plug or microphone. Here's a link to a website that has the marine channel frequencies;
http://www.scanningcny.com/marine.html
Thanks for all the great information.....a great website with loads of information. I have a back-up hand held that I will try and will also follow some of the other ideas. Maybe a new one would not be a bad idea....I never want to be 20-30 miles out without a good working radio. Thanks all
DBH
I would suspect the microphone or its connection to the radio. As cheap as our sponsor sells a new radio I wouldn't spend much on a 12 year old radio for repairs, actually I wouldn't spend anything.
Originally posted by Sandy
With regard to this thread: http://www.boatered.com/forum/topic.asp?TOPIC_ID=124818 , make sure your radio is presently set for US channels not Can or Int'l. On Standards especially, it seems easy to inadvertantly switch. Perhaps easier than figuring out how to switch back :D.
Exactamundo. Very common problem. Switch it to 'USA' and Ýou should be good.
