Silicon Remover
GeeBee
Well-known member
Had to remove some lenses from some lights that were held in with silicon seal. Did not want to break the lenses so I needed something to soften the silicon. I found a lot of expensive stuff that takes a few days to work, but I found this economical solution. Motorcraft Silicon Gasket Remover. On Amazon for about 20 bucks, it took two applications and about a day of sitting but the lenses lifted off nicely. It helps if you can put a knife into the seal to help the stuff penetrate, but give it enough time and it will break down the silicon. Doubt it will work on 5200 but I am going to give it a try.
