Silver Marine Dingy's???
My philosophy in inflatable boats is you get what you pay for. The cheapest boats are vinly air bladders with a nylon or plastic covering, next up cheap PVC, more expensive PVC and finally Hypalon. If you buy a quality Hypalon boat it will last for many years and retain its value. The cheaper PVC boats (read--lighter material--lighter boat, less sophisticated glue process etc) will not last as long. I sure don't want to have an inflatble fall apart on me. Many years ago, I purchased an inflatable--a little less--and one day during a storm, as I was heading back to my boat, I found my self hand holding a 25 hp outboard motor--the transom had cracked from top to bottom on each side of the engine....
If you keep the cheap PVC inflatables rolled up and stored, to be used occasionally they can be satisfactory. But if you want to leave the inflatble out in the weather, go with Hypalon and a quality builder.
