Simrad Autopilot "no drift mode" ?
praetorian
Has anybody tried this? Does it work as advertised?
Apparently it is supposed to allow the autopilot to follow a course without entering a waypoint, but not drift off course at all.
According to Simrad it uses the COG info from your plotter (NMEA VTG) and the heading information from the pilot's compass to determine its own cross track error and correct for it.
A handy feature if it works!
Thanks.
Yes it works well. But you need to be aware of the fact that "nodrift" mode changes the way the NAV mode works...at least on my AP25 Autopilot.
With No Drift mode ON, when you set the Autopilot to NAV mode the Autopilot will steer boat in the direction you were heading when you entered NAV mode. Autopilot will keep you on a straight line using GPS position information(wind and current effects are elminated by the auto pilot).
With NO Drift OFF, Activating NAV mode causes the autopiolt to follow the route being plotted by your GPS. In other words, with NO Drift OFF, your autopilot will make the turns necessary to keep you on the GPS plotted route. Activating NAV mode when no active route is being plotted by the GPS results in an error message.
I find NO Drift mode OFF is much more useful as I normally use Routes on the GPS.
You might want to try it to verify that yours works like mine does.
Thanks Mike, I'll check that. From the manual on the AP16, I believe the no drift is active in Auto mode and the Nav mode is a seperate function for following waypoints. I'm going to reread this section on the manual right now to check, though.
