Since we're talking bottom paint...
Humbucker427
I'm located on the Tennessee River in Chattanooga. The boat stays in the water year round and it's stored in a boathouse. What kind of paint would you guys recommend?
The local yards usually use hard antifouling (Interlux Bottomkote w/ Irgarol), but it appears the suggested type is the ablative for my region (Bottomkote ACT w/ Irgarol).
I guess my question would be why would I chose one over the other? I am very familiar with what each does, but is there something I'm not considering? I'd like to get several years out of a paint job, which I understand isn't abnormal for my region.
Thanks!
I have the boat in water year-round (covered slip) on the San Joaquin River on the California Delta. Just slightly brackish in the summer and fresh water during winter. Our main fouling problem is algae.
I have very good luck with Bottomkote and Bottom Kote ACT. The Bottomkote ACT has better biocide action and will allow less growth during the second season. To tell you the truth I see no particular advantage of one paint one over the other. Each lasted 3-4 years on my boat. Because I have a slow boat that usually doesn't travel at more than 7 kts, both paints required yearly cleanings by a diver after the first year.
The guy a few boats away from me with the expensive Pettit Trinidad bottom paint doesn't do any better.
The difference is weight over time. I like ablative. Mrs. Robinson likes hard. Same boat, same water, 15 slips apart, same results. I have heard good things about Irgarol.
HTH
My current bottom paint is a professional marine bottom paint made by Sherwin-Williams. It's an ablative like BottomKote ACT with the same performance.
I like mult-season ablative because it doesn't build up over time and I won't have to scrape multiple year layers off ever again. Did that once when I went from hard to ablative. Not going back.
Nice to have that foundation of hard paint on first. After that keep up with a compatible ablative.
Yzer, when I scraped all the old flakey hard paint off, I applied3 coats of Interlux Interprotect 2000 so I would have a good epoxy base for the anti-fouling to adhere too. Seems to have worked well thus far.
yzer, I called on Sherwin Williams Paint in Baltimore, MD for many years before retiring. I was not aware they made any anti-fouling paint. I Googled & came up with an association with The Dolphin paint & chemical company. I believe they went out of business because of many, many claims re the performance of their bottom paint.
Are you sure the paint you're using is from SW?
On the same day(1/24/08) you say: "I have very good luck with Bottomkote and Bottom Kote ACT".
Later in the day you posted: "My current bottom paint is a professional marine bottom paint made by Sherwin-Williams". While I called on paint industry, I got all my bottom paint for free. Still have contacts at SW....If they do make AF paint maybe I can still get some free paint. Us retired boaters on fixed incomes have to save money anywhere we can, especially with price of fuel !
A wooden boat as old has mine has some bottom paint history. After I bought it eleven years ago I scraped it down to an old epoxy. I left about 90% of that on: it's kind of a turquoise color and I guessed it was some kind of old epoxy barrier coat. Then it got two coats of Bottomkote.
The next haul out was three or four years after that. The Bottomkote was in pretty good shape so we sanded as needed and put on the Bottomkote ACT.
The last haul out was September '06. I had a partial plank replacement near the bow and had the shop put on new bottom paint while the boat was out. I'm fuzzy on the brand name, but I remember it wasn't Pettit or Interlux and I thought the company was a house paint company. It had "pro" in the name.
Anyway, forgive my middle-aged senior moment. I called the shop just now and when they call back with name I post it here. It's a good paint, but I do remember it wasn't inexpensive.
Originally posted by yzer
...forgive my middle-aged senior moment...but I do remember it wasn't inexpensive.
You are indeed y-ze beyond your years.
