Single Engine Keeled Trawlers
Crossroads
Help me understand the plus and minus of keeled hull trawlers with single engines. For the life of me I cannot figure out how the turning radius will not be huge. I understand the prop protection and the propensity to go straight as well as some help with boat roll when there is a keel but how much this affects the maneuverability in very busy and very tight fuel dock scenarios is not clear. I've always had twin engines and docking anywhere has never been an issue but the thought of having to go back and forth several times just to line up the stern to the fuel dock perplexes me. Since retiring I've learned I no longer need boat speed and the amenities of trawlers are gaining importance.
Because of the prop it will turn very sharp in forward in one direction and the stern will kick in the opposite direction in reverse.
So for instance my Chesapeake Deadrise turns very sharp to port and in reverse the stern kicks to starboard.
So you just have to use that fact.
Example. If I am coming down a fairway I can go stern in to the docks on my starboard side and bow in to those on my port. Its easy to come up to a dock on my starboard, turn hard to port in forward, and then kick the boat in as it walks to starboard in reverse.
Now the downside is trying to get stern in to a dock on my port is basically impossible without a spring line and using the piling (but you can get used to that)...it turns to starboard very slow and when you go in reverse it walks to starboard negating your turn in forward.
If you ever get to Boston, don't ever take a cab from Logan, take the water taxi's....you can see how a pro does it.
You are correct in your observation. In close quarters I use the bow thruster to substitute for the other engine. If I am going forward small bursts will line me up. In reverse I forget about the bow and use the bow thruster to point the stern where I want the boat to go.
Some boats are going to articulated rudders to help close quarter manuvering, including Nordic Tug.
That said, now if I bump the ground I say "oops" and go on. With my previous twin engined non keel boat I would say "bring out another thousand"
Skippers with single engines learn to use lines to great effect. Once you place a bow line and spring line around pilings or cleats you are pretty much in control. On the new trawlers you see bow thrusters and even stern thrusters as part of the set up. The keel keeps you on course in windy conditions around a dock and you just take it easy.
I don't find it quite that difficult, though admittedly I have a "small" trawler at 28'. My stern kicks to port whenever I'm in reverse, but the "back and fill" approach lets me back into a slip to either side. I just keep the wheel hard to port (which unfortunately exaggerates the prop walk), and I reverse, then briefly bump in forward to correct the stern, then reverse some more, then bump in forward, etc. I rarely touch the wheel when doing that.
It is true that you will not be able to pivot on a dime the way you can with twins. But you get used to it quickly and soon you can turn the boat in a small radius by backing and filling.
If you find yourself in trouble in tight quarters, you have to do something counterintuitive: You turn TOWARD trouble. You have to turn toward it, bump in forward so you're pointed somewhat toward it, then reverse away.
you are correct on the effects of a big keel. Nothing wrong with adding a bow thruster.
what amenities of a trawler do you seek? IMO there is little difference in fuel economy of most boats marketed as trawlers and a well designed planing MY. The fuel needed to push a boat at 7 kts is mostly determined by length next by drag which is determined by hull design. Most "trawlers are anything but slippery hulls they are just underpowered planing or semi planing boats.Boats like the Krogen are more slippery true trawler hull shape but will roll a lot. Grand banks “trawlers” are anything but, despite being pretty.
IMO many people will find any slow boat uncomfortable in rougher weather and active stabilizers become a requirement. They work wonders but do add drag and add extra unprotected underwater gear.
FYI my 44 ACMY gets 2-3 NMPG at 7-8 kts and also can do 23 KTs. I wanted the option and have not been disappointed.
There is a small 28-30 foot launch called the Pointer at the dead end of a very crowded fairway off the main dock in Harbor Springs, Michigan. He just fits on a wall with maybe 3 feet to spare. He does tours of the harbor for tourists. There is usually a big Hatteras tied up to his west and we are sometimes tied up to his east. When he leaves, he has a passenger untie the starboard stern line; another passenger unties his spring. He puts the wheel hard to starboard and powers forward until the stern kicks out. Then he unties the bow and backs down a fairway that is hundreds of feet long. When he returns, it is bow first with a hard over to port on the helm at the right time and he has a passenger set the starboard spring, then the stern and he does the bow. I've watched him do this many times in ALL kinds of weather. He is a real pro. No thrusters. The boat is probably 50-60 years old and is beautiful to watch.
Turning is the easy part. You back and fill. On my boat (single screw, right hand wheel, full length keel) turning to port is easy. Get a slight amount of stern way, wheel hard over to port, engine one-half ahead and the boat pivots in her own length. To starboard is not quite as tight but is executed the same way. Docking in tight situations requires slow speed and good line handlers, bow and stern. For a port side up docking, approach dead slow at an approximate 45 degree angle, (I have a manual gear, so just leaning against the clutch lever results in very slow shaft rotation), bow line on, wheel hard over to starboard and the momentum of the boat will slide the stern in, as the bow line is slowly slacked. Going ahead slightly will help kick the stern in if needed. Again good line handlers are needed on the boat, Never, Never just hand the bitter end of a line to some joe on the dock and expect him/her to secure it. Properly spliced eyes in three strand nylon and good line throwing technique, will cause the eye to open up as the line is cast towards the dock resulting in some spectacular "ringing the pile" moments. This all being said, there are times and situations where you are much better off finding another dock or anchoring out and tendering in due to wind, current, etc. The real skill is knowing when to punt and not try.
You realize that not one single person has commented on a keeled hull single screw? As Bruce correctly notes, its a marketing term.
So far the closest boat to a true trawler hull is mine, but I have twins and there isn't much of a real keel anyway.
You might want to think about what you are asking and check whether your impression of what most "trawlers" really have for a hull matches what you think they have.
The answers so far pertain to single screw inboards. The answer to THAT different question is that they are all about correctly using spring lines for landing. Learn that and they are manageable even without having to rely on training whee...ahem...thrusters.
The main advantage of a trawler hull with it's displacement, keel and big rudder is that it's not affected by the wind like a light displacement boat with no keel. It's also easier to push, and one small engine burns less fuel than two big ones.... Just don't get in a hurry.
With any single engine boat you'll learn there's more to boathandling than just the clutches.
But once you learn the "ropes", the throttle, the wheel, and even the anchor you can do just about anything you want. It takes practice, thought, and planning; but it's something you can be proud of.
Agree with Bruce and Ghost. In years gone by a "trawler" (IE shrimp boat) WAS a single-engine boat with a keel, and about everyone knew it. Must be a new buzz-word for the sales crowd.
The Pointer is a deplacement speed boat with a keel. Technically not a trawler, but if you can handle a boat like that a trawler will not be much different.
Hey Bill,
We have had many years experience with sailboats where the rudder was the size of a barn door and the ability to back down a fairway or docking was always simple. Then as we looked for more creature comforts we to went the way of the trawler. Being from the sailboat environment I wanted something slow and sure. Meaning while at sea I wanted to go through the sea not on top of it so we looked for a heavy full displacement boat. Since speed was not a factor a single engine would fill the bill. We settled on a single screw 44' hard chine flat bottom in the aft 46000 lb trawler with 3 foot draft and a full keel.
To dock stern in we do a lot of back & fill. We have no steerage with the rudder while going aft we will only go straight unless the wind should decide otherwise. When we need the stern to go to the starboard we keep the wheel hard to port and place the shifter in forward for a few seconds, apply a little throttle, idle down then back to reverse. This procedure will be repeated as required.
If you keep the wheel hard over and repeat with a forward and a quick burst of throttle then back to idle then to reverse and a quick throttle and again back to idle you will turn in a circle. Once you master this you will be able to turn a single screw in a distance of just over your boat length.
I single hand most of my boating, but when I have any sort of a crew I try to keep them out of harms way. Most people will try to stop you by putting a foot out against a wall or piling. This is good way to end up on crutches. Don't be intimidated by the art of docking with a single screw just take it slow and easy.
Good Luck Skipper,
El Sea / L.C.
Ghost, What do you define as a keeled hulled hull single screw? I know that I have a full keel and a single 330 hp engine on my Nordic Tug. I don't have stabilizers but don't roll much and I cruise at 8.5 kts, which is 2 miles to the gallon. I must not understand the question. I thought it was about manuvering, not how to define a trawler. Did I miss something?
Ghost I think I said he was correct in his assumptions, anyway he is.
Whatever, have fun with your marketing materials.
I am truly lost. What does marketing have to due with the turning ratio of keeled single engine boat? I am not trying to rile anyone up, I am simply confused. Some please take me by the hand and explain it to me.
I guess I'm taking the term full keeled single engine too literally. Look, none of us have full keels, including your Nordic Tug. They just are not that deep. My Tolly has a full keel and heck I even have round chines, but still behaves at docking speeds very characteristic of most semi-planing boats. At docking speeds, even the addition of hard chines does not make THAT much difference.
In a practical sense, the kinds of keels we have are noticeable over a planing hull, but are not really limiting. If anything, they help maneuvering because you don't severely slip sideways just by turning the boat. In my 28 deep vee I could run the boat down a fairway spin her on her beam (without slowing down) and quite literally turn her on her beam and the boat would continue moving sideways but straight down the fairway for a few boat lengths (reverse chined, but round keel deep vee). On our more typical style of semi-planing style keels, they are really planing hulls with a bit of a more pronounced keel for tracking, you can still side slip. It's not like you have a fin keel in the water you can exactly steer around. Also, if you have a "fast trawler" immediately you know the rudder is not going to be big ( you can't have that much drag and go fast when you want).
Bottom line, don't fear the types of keels we are talking about. Nobody here has a full displacement true trawler type of hull. The keels help for tracking, but do not get in the way for docking. If anything, they lend just a little bit more predictability to the boat. On a single screw, it will help a "little" with prop walk, but not enough. You still won't be able to back straight down without making directional corrections. If your prop is big enough, the keel likely won't come anywhere close to overcoming the propwalk, the propwalk will overcome the keel.
So....my net net is that for all practical aspects, you can just pay attention to "single screw" docking advice and ignore everything else. The hull features are just not going to be pronounced enough to make you take fundamentally different actions in docking.
But, a single screw inboard IS a big difference if you have not owned one previously. I personally would opt for a bow thruster on a larger boat. I would not try to rely on it, but I would equip with one.
bp
"Nobody here has a full displacement true trawler type of hull."
Not true I do LOL.
Does this count?
Mine has a fairly deep keep running all the way aft. Like Ghost says, I do think it reduces sideways slip. Wind has a less-pronounced effect too, although current can do a pretty good job on me. Again, you're not going to spin a boat like this the way you can spin a boat with twins. But you can carve out a pretty tight turn if you know how.
