Single handling, safest length
Hat-70
In a flush deck motor yacht what is the longest yacht, i.e. 53, 55, 60, 70..., that a person can safely singlehand?
depends on your experience.
i have no problem single handling my 53, i don't see how an extra 10' at the bow and 10' at the stern woudl make any difference, layout is far more critical than length.
when you have a pilothouse with side doors and quick access to your spring line, you can single hand almost anything. It's critical to realize that once you get over 45/50', you're not going to muscle the boat around anyway... you're going to use spring lines and once the boat is in position, it's not going to fly away at the first gust.
extended deckhouse layouts appear to be a little more challenging but they're no big deal. you simply walk thru the saloon to get to your stern lines, the distance is the same.
a bigger issue is visibility aft from the pilot house. boats with a bulkhead, galley up ,etc... have little visibility aft which may make backing up into a slip a little harder as you need to step aside to see where your stern in. it may take a little more pratice...
but again, it's all about how much experience you have.
Hat-70,
I would think this depends on ones experience and their physical abilities. The majority of my boating is singlehanded or with unskilled charters but for my two-cents, you asked.
My preferences for layout are:
1.)A vessel with walk around decks so as to reach the mid-ship cleats
2.)Two doors to deck from Lower helm
3.)Upper & Lower helms, upper for docking and close quarters, lower for deck assess
Good Luck,
L.C.
single handling a boat from an upper helm is a PIB... you have to rush down the stairs/ladders to get to your lines. Docking from the pilothouse is a much better option.
larger boats should have two sets of midship cleats, I usually rig my spring lines from the forward mid ship cleat, ahead of the pilothouse, so access to the sides aft of the pilohouse is not that critical, it helps but you can easily do without.
More important than length, I think, are access, visibility, and knowing the limits of your skills and mobility.
I agree with Pascal, easy access to the spring cleats is more important than length
I think it has more to do with experience and docking skills. Motor yachts, of course are tougher than sportfish/convertibles and express style boats. Properly set up dock and spring lines along with a few practice tries with a mate or two, just in case, 'till you get the hang of it. Then, there's no trouble when you do it solo. Knowing when to back off and give it a second try is also very important! No reason to feel embarassed on second tries, airplanes do it all the time!
"Motor yachts, of course are tougher than sportfish/convertibles and express style boats"
nope... see above. Most larger MY have pilothouse and direct access to side decks and spring lines making them MUCH easier to handle than a sportfish or flybridge boat where you have to come down the ladder or steps. Even easier than an express when you need to first go aft and then around the side to get to your spring line...
The number of steps, stars or ladders from the helm to the spring line is what's important when docking. Climbing down then back up a ladder to a bridge would not be my idea of easier.
I would rather single hand a 100' with a lower helm and doors than a 30' SF with a ladder.
When underway larger vesesels have an easier ride and are less tiring.
A remote helm, wireless or on a tether can make a big difference for single handling (or even with a deck mate for that matter!).... on a boat with side decks of course!
My guess would be a lot shorter than 53 feet. With deference to those above, 53 ft. is a lot of boat in a wind or in a narrow fairway. Sure, big boats don't blow around like a smaller sedans or sportfish boats with a lot of sail area, but they don't stop as quickly either.
I've done some short deliveries up to 47 feet - sportfishes, convertibles and one or two trawlers. I always put out bow, spring and stern lines on both sides before I leave, all so I can grab them in one hand if I get into trouble. If the boat is new to you, you never know how it will behave. On some boats, even leaving a dock, you need someone to tell you when your swim platform is clear of a spile before you turn.
Personally, I wouldn't run a powerboat bigger than 38 feet with no one else aboard, until you really know the boat. In time, you and the boat get to understand each other.
I get by pretty well in my 53'. If I am coming in starboard side to (my preference, and same as my slip) it is really easy to come in from the pilot house. I probably drive from the pilot house 80% of the time. In the pilot house I am at eye level with the rail. I have excellent vision to at least two points abaft the beam on each side, and my view dead astern is not too bad. The rail is the outermost limit of the boat. I feel like I have a better depth perception from the pilot house than up top. The captain that I trained with cringes when he see me driving from the pilothouse but I like it. Also, better nav equipment in the pilot house. Plus snacks...
