Sirius Weather
Robski97
Anyone else having a signal issue ? Bunch of us up in NY have no signal. Sirius Tech service says there is no outage .
thanx
No problems down here in southern NJ. Was a high power WiFi system recently installed in the marina or in a boat near you? Or is this a widespread problem? Some high power WiFi set ups can interfere with SIRIUS Wx. You can usually find the culprit by moving your boat out of the immediate area of the marina. Now to solve this problem the WiFi provider needs to do one of two things either turn down the power or purchase a channel filter from HyperLink/L Com out of NY. You better hope it is not the new type N protocol the only option there is reduce power. When I 1st installed my Syrens HotSpot systems in the marina certain boats would intermitantly loose SIRIUS Wx. I took my boat down to that end of the marina (the gas dock) and sure enough it would come and go. I reduced the power until I got a filter for the offending WiFi HotSpot. The HotSpot now performs better because with the additional filtering it reduced noise into the receivers front end. Also make sure you have your SIRIUS WX antenna mounted outside even though they claim you can mount them inside the boat you will loose the signal very intermittantly because of the vessels attenuation properties.
Bill,
TY. Optonline does have hot spot here. Humm... Antenna is on the hard top.
Originally posted by Robski97
Bill,
Rob how about checking the connectors what do you have Raymarine or Garmin? I know my old Garmin unit had a male/female connection at the antenna possibly you have water injestion. Water in a connector at those frequencies is a killer. I would also go look on your network plotters site to see if there are any updates in the software. Thats why I love Garmin I installed a program that writes software in my laptop and all you need is a small 1 to 2 gigs memory SD type card device. You download from the internet to the card and place the card in the plotters if they are networked it updates all devices software at once. You can buy the memory cards at Radio Shack and keep your network up to date.
Sorry I meant to say SD cards.
How about any new boats that recently had a high power WiFi system? I have no problems on my own boat but some of my neighbors say they can't use SIRIUS Weather when they are docked next to me. I turn off my highpower WiFi when I don't need it and then they can. Most of my data is done through my Ericsson W25 unit on AT&T.
That's it Bill, I'm calling the FCCC on you ("Federal Can't Communicate Commission")
Bill,
Its not just my boat. The only 4 boats with weather have no signal.
On my laptop only wifi i pick up is optonline.
It wouldhave toe very strong Rob, what does it say as far as signal strength? We had 8 boats wiped out when I 1st installed the system at full power prior to filtering.
7 on scale to 10
Thats not strong enough Rob you would need to get blasted for it to interfere. How about any wireless cameras recently installed at the marina?
Bill,
No cameras. As of this afternoon everyone was still out. Very odd.
