slow shifts into forward
justgotaboat
I noticed yesterday that sometimes (and possibly more and more frequently) my boat takes several seconds to shift into forward gear. When I place the throttle into forward, it used to click into gear almost instantly, (I know because you could hear the water move when docking in certain situations with the outdrive up) However now it takes a few to several seconds sometimes. It shifts smoothly and does not make any bad sounds, it is just delayed sometimes. I think it could lead to problems since I do not have the control I want, and if I were in the situation where I gave it more than just idle throttle trying to dock it would be slamming it into gear at a higher RPM which would not be good.
Any ideas on what i should be looking for as a problem? Is there some kind of adjustments that I can make? or leave it to a professional? Its a '01 245 sea ray weekender with a Bravo III and stroker 383.
How clean (not sticky) and recent (how long since replaced) is your Lower Shift Cable? If it were sticking, I can imangine where it "might" allow you to move shifter into gear but it isn't doing the actual Push/Pull to the outdrive till it overcomes stickiness. Have you overheated the exhaust? IF the cable was touching the Y-Pipe area, the neoprene components of the cable could have softened and that'll make it draggy.
If that's OK, change the Outdrive Lubricant. And let us know how the lube you drain out looks.
Remember, Bravo shifts with a "cone clutch" not a "dog" like Outboards and Alphas and it shifts in the UPPER gearcase. Even though it's not a dog-style, the Cone/Bravo should still go into gear with one solid CLUNK.
My 2000 SeaRay 270 Sundancer has had this "sluggishness" the past few seasons. Marina suggests clutch repair which isn't cheap i.e. $1400. In the meantime, I take it easy in & out of slips. With a little experience I find I can compensate for the "lag" time. I'm told at some point the outdrive will be very difficult to engage with the motor but this will happen gradually. I'll delay the repair as long as it makes sense to do so.
I had the same thing last year although I have volvos. Two second delay. Bad shaft seal let water into the outdrive which mixed with the oil causing the delay.
I checked the oil and it looked ok. Cables seem to be routed ok so they are not overheating. We repowered her last year at the start of the season. I do not recall if the cables were replaced at the time or not. It still shifts into gear with the same cluck... its just delayed. and the delay is not just a second or two... my delay time seems to be much longer. We took it out on Tuesday and it was several seconds. As much as 5 or 6... which is far from where it was a just a few days of boating ago. It's causing some considerable docking issues (which is rare for me... i can usually put my boat where I want easily... the delay is just too long to account for). Unless anyone has other recommendations she is going to the marina I think. If it seemed to be a small delay that I could get used to I would hold out... but I don't wanna be penny wise and pound foolish and slam into something because she would not shift right.
My 2000 SeaRay Sundancer has had this problem for the past few yrs. As oldfishboat says, I've been told this is likely a clutch problem. The repair at my marina will cost approx. $1400. For now I've decided to baby it & I go in & out of slips slowly. With some experience & extra effort I find I can safely compensate for the sluggish handling. Obviously, I'm trying to save the big bucks until it further deteriorates. I don't believe this will add to the eventual repair costs.
