Soft Area On Bow
DRB292
Hello and thanks to all that replied to my other thread on the toilet. I have one more question. On the bow of my 1996 292 regal, in front of the hatch, there is about a foot square area that has some flex to it. There are no cracks and it seems no worse than last year. There are no leaks or evidence of water intrusion. Could the boat just have a weak spot from construction? I need to walk there to let the anchor out. I do not want to take down the headliner and take everything apart if not needed. I am 210 and could loose 15. That might be cheaper than a fix. Thanks
IMHO, there should be no "soft spots", even if I walk on your deck ( I'm at around 250... ). This means that something is wrong. The most likely cause is that you have had water intrusion, and the cored deck ( most decks are cored ) has a problem with a damaged core. One other possible is that ( location makes this somewhat more likely than other areas ) the area has received a very hard mechanical stress, which resulted in delamination of the core from the glass, which greatly reduces strength. If this is the case, you really need to fix it.
The best way to check is from the interior, by drilling shallow holes through the interior glass into the core ( but -not- through the exterior glass layer ). Look for "excessive moisture" in any of it's varieties. It should be dry. You certainly -could- go through the top, but you will be damaging the "finish" layer and that is hard to repair to original specs ( including color! ) Your deck may look like it has the pox! ;)
BTW: There are two very good reasons why that deck should be solid. One, is that from time to time you may have guests ( or, perhaps, a USCG boarding party ) on the deck. You really do not want a guest to either fall through, or fall overboard due to unsure footing. The other is, of course, that in a "high stress situation" when you are on deck trying to rapidly set or retrieve the anchor, you really do not need the additional concern about your footing. And we need not discuss the issues if it fails during a high stress situation.
Bi
I think that someone could of fell working with the anchor and stressed the glass before I got it. Can something like that be repaired without replacing the inside section of the damaged core? Could it be braced somehow? I would think that this job could get very messy if I have to cut the core inside the boat.
I'm with Bill. If the core is compromised, find out why, usually a leak. You can repair it from the inside without any cosmetic impact to the outside of the boat. Repair core is not nearly as hard as it sounds. If you have good access from inside, you can have it opened up and new core in, in a day. Sounds much worse than it is. As you indicate the headliner is the worst problem. If you are careful you can get them down and back up. If it is just glued carpet, that's actually easy most of the time, other materials YMMV. But....really really good idea to find out what's going on with the core. Very suspect being next to a hatch. Have you tried tapping out the area as a diagnostic?
I have not tapped it out, but the damage seems only to one area.The area that is soft is between the hatch and the anchor locker. The headliner is vinyl and it is removable. The hatch is a type that I would not think would let water in, but it could. I am a auto body technician and have worked with glass before....I just dont like to.
Something that you said makes me think that there may be nothing going on there. And that is that it seems to be the same this year as last year. It is this statement that makes me think that this may be an area that did not sufficiently bond from day one and that it has not gotten worse over time.
You can do a couple of things to help yourself out at this time. One is to tap the area out and take note of the perimeter of what you consider to be defective. You'll be able to determine what is solid from what is not by the sound.
The second is to borrow a moisture meter and try to determine if there is any moisture under there. If you cannot detect any moisture, then you may not have a serious problem. If you do, then all bets are off.
Unfortunately, this is one of those cases where the cure may be worse than the illness, particularly where aesthetic value is concerned, and you may be better off to monitor it for this season, or some part thereof to see if it gets worse.
And finally, I have just taken off 25-lbs. since Valentines Day - 227 down to 202 this morning. I eat less, much less, and I walk at a minimum 3½ miles each and every day, religiously. My goal is to get down to 180-lbs by June 15th, and I know that I'll do that with ease. That's all, brother.
Is it possible that its just an area that the manufacturer should have reinforced but didn’t? The fact that the space is between two large openings (you mentioned the hatch and the opening for the anchor locker) means that the area should have been reinforced during the building process like adding extra FG mat or a support rib or two glassed over from the inside. Can you feel the thickness of the area where it flexes? Does it feel like it may be too thin? Check with other owners with the same boat and see if they have a similar issue. You may be able to add a glassed in rib underneath somehow if its not water intrusion.
It could be just flexing in the deck as a normal course of the construction of that model. My SR 290 had some flex in the deck, looking below you could see why, a single small bulkhead, a result of trying to create a large open cabin. Put a big hatch in the middle and there simply is not a lot of support for the deck. I was worried like you until I got on the deck of a few other 290s and noticed the same thing. Try and find another model like yours and check it out...be careful trying to fix something that isn't broken. A soft core is not going to just flex, it would amost feel squishy where you step on it. Pulling a few screws out of the hatch frame would give some indication as to the condition of the core.
before you do anything i would contact Regal. there is a limited lifetime warranty on the hull. find out from them if yours is a water intrusion problem or a delamination issue and let them suggest the correct course of action.
From your description it sounds like the soft spot is "downstream" of the hatch.
It's possibe that the hatch leaked and water got ino the core. Most hatches have an inside trim piece. If yours does, remove it. It should expose part of the core and you can get a peek at what is going without removing the headliner.
I had to replace all the coring around my hatch last year because of this exact scenerio.
It is a messy job, but if it needs doing don't ignore it.
Well, I just got off the phone with a service tech from basa marine out of Chicago and he told me that without any sign of water intrusion, that he wouldnt do anything about it until the end of the season. I tried to get regal and they were out to lunch. I will try them back in a bit. He also said that he has never seen a core failure without external cracks in the gel. He said that in the area of the nonskid that it should crack quicker than smooth. I will keep this thread up to date on my findings.
