Spider cracks around top side portals
BVasily
Noticing a few spider cracks emenating from the three portals on the top side deck. Is there an easy fix that does not require grinding out the fibreglas?
any experience here is welcome.
Bob.
gel coat is less flexible than the actual fiberglass in my experience. a dremel down to the glass and then clean the routed out area to see if it went further as you may not need to go into the actual glass. I do not know of a trick though.
