Spring launch projects: bottom paint, waxing......
Silver Lining
Hi I am in need of advice on a couple of spring projects. We are soon to launch and are about to bottom paint and do a thorough wax. I know some of these items have been discussed before but I have questions that are specific to current paints and Florida and Chesapeake water.
Bottom paint. We have Micron ablative on currently and this worked well last year. There was some soft build up but everything came right off when pressure washed. We will spend a few months on the Chesapeake and then several months in FL and the Bahamas (much longer than last year). What do you recommend and what are your personal experiences with Micron Extra or Micron 66 versus Petit Ultima SR 60 or Horizons. I believe all of these are co-polymer ablatives and compatible with our existing bottom paint.
Waxing. We have previously used a turtle wax 10 inch buffer that has a 1 amp motor and spins at 2400 RPM. I am looking at getting a second buffer and would like opinions on getting a polisher/sander with a 4.5 amp motor that spins at 1200 or 1400 RPMs. This appears like a right angle grinder but those spin at 8000 RPMs and will damage the gel coat. The picture on the box shows someone waxing a car? Do you use a buffer or have you tried a more expensive and more powerful low RPM polisher? I think the more powerful polisher may be well suited for rubbing compound.
Thru hull fittings. What is your procedure for cleaning and exercising your thru hulls prior to launch? I was planning on spraying the balls from the underneath side and working them. It is a bit tricky as they all have some kind of strainer but can probably get a WD40 nozzle in and give a good spray to the ball itself and then the external bilge components as well.
Do you paint your running gear with one of a few different zinc paints made to spray directly on the props or shafts?
Thanks in advance for your thoughts. I have an early launch date and have a few decisions to make in the next few weeks. Boat is a 50 foot Viking Sport Cruiser with a 20 knot cruise speed.
-Rick
For FL and the Bahamas I like Trinidad Ultra.
As to buffers, look at the ones from Harbor Freight or you can go all out and get a Makita. Don't use wax after compounding and polishing. Use Zaino, Pro Polish or something like them.
Remove your thru hull screens when you paint your bottom. So you can clean them and paint them. As well as getting up into the thru hull holes for cleaning and painting. And don't paint the screen holes shut by putting to much paint on them with thick cooats.
If you can, close the thru hulls and fill them from the top with penetrating oil or spray. Let them sit at least over night and then work them back and forth. Some thru hulls you can lube from a fitting on the side of them.
"Paint" your running gear with Prop Speed.
Turtle Wax 10" Buffer. Is that really an orbital buffer as opposed to a rotary buffer? If it is, IMHO you are wasting product and time. I've been using a $50 Harbor Freight variable speed rotary buffer for years with great results. I leave the orbital at home for use on my cars.
Capt Bill, the Trinidad is a hard antifouling paint that I believe is not compatible with ablative paint. Not wanting to start from scratch, I was hoping to get opinions on the Micron versus Petit ablative paints.
I sprayed the thru hulls with WD40 and all are working smoothly but one that is hard to get to and not exercised regularly. I cant fill it from the top easily but will get penetrating oil unless someone has a better recommendation.
I did find a few threads in the other section of the forums on buffing etc. It seems that many people use the polishers that look like angle grinders and not the the standard 1 amp 10 inch orbital buffers. I will pick up a buffer/polishers that spins around 1500 RPMs.
Thanks, Rick
I use a porter cable with Collinite Fleetwax and could not be happier with the results. It was always ranked the highest by Powerboat Reports when they were around. 20 year old gel coat.
Picked up a polisher/sander today from Harbor Freight. Great deal. $35 for a variable speed 10 amp polisher that goes from 200 to 3000 RPMs with a nice speed control dial.
We have been using Fleetwax and 3M wax/cleaner, but the previous owner used Mothers wax and the hull sides looked fantastic and still do with very little cleaning, waxing, and upkeep.
I guess we are going to have the marina use Micron Extra or 66 and see if they will apply the Prop Speed to the running gear.
If your boat bottom has an ablative paint and you want to go to a hard paint, do you have to strip off all the old stuff including the primer? I want to use a hard paint because the ablative comes off too fast and we need to clean 2 times a month when its summer. The boat was soda blasted the last time it was done and they sure did a mess of the bottom so I am afraid of getting it done again. Any thoughts? Also, is this something I can do myself or is it not worth it? Any thoughts?
Originally posted by Gregory S
Put a good polish on after the cleaner wax.
Most "polishes" like Zaino and I believe Pro Polish are incompatible with wax. The surface needs to be wax free for them to adhere to it.
