SPRING LINE ADJUSTMENT FROM DOCK
ladylove
I use bow and aft spring lines tied to aft and fore dock poles to the boat's mid cleats. NOTE: THERE ARE NO FINGER-SIDE PIERS)The eyes are set to the boat. I board at the stern.
Due to a recent unexpected storm, my boat stern took a beating against the dock even though stern spring line was set for at least 2 feet from the dock.
Is there a way to install the stern spring lines which is currently attached to the fore dock pole to protect the boat's stern) that will permit them to be tighten to allow for storm surge and loosen for boarding, either or from the dock? Maybe a pulley on the fore pole with spring line from the amidship cleat to the pulley to the dock ??? Not aware of such. Help
Bill Love
lovebox3**aol.com
i use a couple of old fenders hooked to the dock to protect my swim platform from such things as storms and backing in to the slip
you could probably use a pulley although that's one more thing to fail, to inspect and to maintain...
how big are the tides, solomon island MD station shows minimal tides so that shoulnd't be a problem.
what kind of lines are you using ? 3 strands stretches more than braided which is what i use and never had a problem even in strong winds.
i never use the eye on the boat cleat... not only it prevents you from adjusting the lines but it also makes it much harder to attach the line when it's windy... if you use the bitter end on the cleat you can work the line agaisnt the cleat. just use a nylon tie to mark the spot to set it right.
with braided lines, i have the boat set about a foot from the dock (so that my dog can jump from stern to dock) and it has never gotten closer even in 30 or 40kts... for the last hurricane (90kts+) I had it set a little farther and again no problem, stretch was minimal.
make sure your spring lines come from the forward piling to the midship cleat, or from a midship piling to the stern cleat. but with minimal tides you shoudlnt' need complicated pulleys.
cant/shoudln't rely on fender to prevent damage. it may limit the damage, cosmetics, but if the boat is really backing into the dock because of strong winds the fenders are not going to stay in place or last very long. With the right lines in the right spots, you dont' need fenders in a slip.
In a similar arrangement as yours, I used a pully on the forward piling. The line ran from a midship cleat to the pully back to the dock piling at the stern.
When leaving at night I could pull the line so the boat went further out from the dock. On return, I just loosened the line and could pull the boat to the dock with a stern line.
Went thru a number of major storms and never had a problem. Just need to make sure you use a hefty pully and long lag bolt on the piling.
Capt Tom
i woudnlt trust a lag bolt ! yeah, I'm a little paranoid... what i'd consider if i really needed to adjust the spring line from the dock would be 1" SS tube, bent to follow the piling, mounted on the forward side of the piling. pass the line tru... attach one end to the midship cleat and the other end to the dock.
You need less stretch in the spring line. Possibilities:
1) Switch from 3-strand nylon to braided nylon;
2) Up the diameter 1/16 or 1/8 inch;
3) Add a spring line on the other side;
4) Some combination of the above.
You mention storm surge. This suggests wave surge, to me, which creates shock loading on the spring line, and transfers that heavy shock load to the cleat. Long-term, find a slip where wind-driven wave surge is not a major issue.
pascal said, "cant/shoudln't rely on fender to prevent damage. it may limit the damage, cosmetics, but if the boat is really backing into the dock because of strong winds the fenders are not going to stay in place or last very long. With the right lines in the right spots, you dont' need fenders in a slip."
The fenders in my slip for in case of a line or dock cleat failure. Of course, I'm not in hurricane territory! I think it would be good to be a little paranoid if I were......
well i guess it doesn't hurt :-) but really lines don't snap without warning (chaffed) and you can usually tell when a dock cleat doens't feel right.
in hurricanes or stronr storms, fenders dont' do much good either. i was lucky to be aboard during both wilma and katrina here in miami with winds of around 100kts and i learned a lot. fenders will only protect the boat in case of contact not only if oversized but with strong fender boards. otherwise, it's not even worth putting them out, boat moves too much and the wind blows them around.
even in normal condition, i'd rather have 2 sets of spring lines : one pair from the forward piling to the midship cleats, and another pair from the midship pilings/finger cleats to the stern cleats.
I'm confused, the aft spring line if long enough should not cause the boat to come closer to the dock and it sounds like you have plenty of length. If your spring lines need more length, tie them to the bow and stern cleats instead of the mid ship cleat. How long is the stern line (not the aft spring line) and is it tied to the inboard or far stern cleat? Those are the lines that in my thinking determine how close your boat wants to ride to the pilings.
Maybe I've just got the wrong picture in my head.
bp
i think we're talking about limiting fore/aft movement, into the dock at the stern. that's controlled by the spring lines.
to control side to side movement and keep the boat off the side pilings, then yes that will be controlled by the bow and stern lines.
Thanks Pascal, yeah your right that was actually made clear I just didn't build the correct mental picture.
If you are in an exposed slip or partially exposed slip and the adjustment of the spring lines are not helping. Think about getting several large airplane tires (much wider than truck tires) and chain hanging them along the aft face of your slip. You can get white covers sewn for the tires to prevent marking of your hull. You will need a special drill bit to cut through the tire and cords, but they will take the shock that would flatten a yacht fender. If that will not work purchase a small or medium sized Yokohama Fender. They are about the size of small car and generally require a crane to move and set.
Pascal, I'm curious how you would tie up in a slip without pilings, portside finger only, a 9 > 11' tide & not use fenders.
Al
al
this thread is about tying a boat in a slip with pilings on both sides and minimal tides... any time you're tied along side the dock/finger with nothing to hold the boat off the dock/finger, clearly fenders are a must.
now how do you get down to the boat at low tide ?? dont' you have floating docks in areas with large tides ?
Pascal, up here floating docks & many marinas don't have pilings. Go south of the Cape Cod canal & many marinas don't have fingers, just pilings with a stern tie up like you are talking about.
Al
