teh easiest way to leave a dock is in reverse, not forward... in forward, you will always kick the stern into the dock.
with twins, you don't even need to use a spring line... if the dock has wood pilings you can pivot off the pilings, if not, then you just need to place a couple of fenders at the bow. Put the dockside engine in reverse (stbd if docked to stbd), off side engine in forward and rudders hard over towards the dock. the twisting motion and prop wash will kick the stern, while the dock side engine will stop the boat from moving forward. When you're at a 30 to 45 deg angle, put the off side engine in reverse and back out.
in theory you could do the same forward, put it's harder to protect the swimplatform and if not integral, it puts a lot of stress on the platform.
never tried this with twin sterndrives, but it shoudl work too... although you might need to increase RPM since you have less torque.
i use this method all the time, even when pinned by strong wind, i leave with no effort...
or instead of a pair of $50 fenders, you can drill a big hole a the bow and install a bow thruster... total cost... 100 times more ... but it looks cool... push a joystick, makes a nice coffee grinder sound...
