Spring Prep- What needs to be done?
bmfesq
In the past I have had my marina do everything to my boat to get it ready for the water in the spring.
What really needs to be done/changed/adjusted/ replaced every year?
What things can be done every other year?
What fluids should be changed each year?
Depends on what is done in the fall as well.
- Change engine oil and filter - Fall
- Change fuel filters - fall
- Remove outdrive to inspect gimbal and grease - Fall
- Remove props to clean and inspect for fishing line - fall.
- Replace outdrives - spring
- Replace props - spring
- Disconnect batters - fall
- Winterize all water systems - fall
- Springize all water systems - spring
- Paint bottom - Spring
- Paint outdrives - Spring
- Replace zincs - Spring
- Change plugs - depends on plugs - can be every 5 years if platinum
- Change distributor cap and rotor - every 2 years
- Change belts - every 5 years
Check your books or go online. Every manufacturer has different schedules.
My list for this year
Do - X = Must Do Before Boat Goes In
Schedule bottom paint X
Schedule outdrive install, zincs X
Schedule timing check X
Schedule launch X
Mooring Cover: Clean and Spray waterproofing
Schedule bellows replacement X
Remove shrink-wrap X
Check Hull X
Clean battery terminals/connectors, install batteries X
Inspect 120V connections/system X
Check battery charger/charge batteries X
Check trim tab rams for wear/leakage X
Check trim tab oil level X
Check trim tab function X
Count how many seconds for full trim tab cycle X – 6 sec
Test fish finder X
Clean screens on all bilge/sump pumps X
Check all bilge/sump pumps X
Wash hull X
Compound hull X
Wax hull X
Check portholes for leaks X
Check sparkplugs, wires, coil and cap X
Check Oil Level X
Change Fuel Filter X
Check/run blower X
Clean engine room/bilge X
Check Seacock X
Check boarding ladder X
Put on registration X
Flush/sanitize fresh water tank
Flush water heater
Check sink
Check shower
Check wash down
Test VHF
Check inside/outside lights
Check GPS
Check fridge
Check fuel gauge X
Check starter circuit for corrosion X
Check O/D oil level X
Check for Fuel Leaks X
Start/check engine X
Check Steering X
Check voltage output X
Check oil pressure gauge X
Check trim gauge X
Check engine temp X
Check/shift gears X
Check prop X
Check navigation lights X
Shampoo Carpet
Fresh water hose/spray handle at dock
Clean fridge
Put plug in boat in a conspicuous place so that marina can’t miss it X
Shake down cruise
Seal cracks
Put holding tank stuff in holding tank
Test Handheld VHF
Waterproof rear bimini
Install Bimini (back bimini)
Wash down Boat (tilex deck)
Clean garage
Fix oil pressure switch X
Check hot water heater function
Fix carpet for solon floor
Check toolbox for all tools (needs wrenches, adjustable, vice grips)
Test spotlight
Map out serpentine belt around pulleys
Check fishing poles/crab traps
Drink Beer
Load
Plug X
Dock lines X
Tool Box
120-Volt Line X
Mooring cover
Spare Lines
Junk Box
Flairs, Horn, Life Jackets…
Spot Light
Fenders
Bungee for Fenders
Bimini
V berth cushions
Aft berth cushions
Rectifier
Air pump
Inflatables
Koolies (need a few more)
Paperwork (safety cirtificate, dmv, towboat)
Bathroom/galley stuff
Pillows/Pillowcases
Boat Poles
Horn
Paper Plates/Bowles
Plastic Containers
Blankets
Batteries
