Stand On Moron
Originally posted by mintregila
...it was also clear that...he did not intend to change course or slow down, so I throttled back and let him pass in front of me.
When my wife looked up and asked why I was slowing down, I pointed him out. She asked if I had the right of way and I told her yes. Whe she asked why he wasn't slowing down I cited the idiot rule which briefly states that if a dangerous situation arises and one party is an idiot and the other is not, the non-idiot needs to take evasive action to protect himself from the idiot.
Live By the Idiot Rule. Die by the I'm Right Rule.
thanks m'treglia...
Wasn't the Andria Doria in somewhat the same situation with the Sockholm? They were a bit bigger and there was fog.
That was what is known as a "radar assisted collision". Without radar it probably never would have happened; but yes, the left turn on the part of the Andrea Doria was not the greatest idea.
FWIW:
As a Safe-Guard I assume all large pleasure crafts are operated by some idiot who had the funds to buy such. This does not mean we are all idiots, this is only my Safe-Guard. There are for the most part seaman out there and then there are showmen out there. One has the desire to be a safe mariner the other an accident looking for a place to happen.
I try to take every evasive action I can to avoid any act of emergency. We practice the tonnage rule - he with the most tonnage rules. Of course I am not going to run over the skiff with the kicker because I have more tonnage.
I strongly feel that before a state vessel registration is issued, the owner should show some form of reconizing the rules of the road, whether a CG Aux test, a state test or an online test.
It is too easy for Mr Big Bucks to go out and buy a nautical killing machine.
Originally posted by KPMid
That being said, 10 'o-clock would not normally be considered "head-on". That's about a 60 degree difference in heading (assuming a risk of collision exists) and would most definitely be a crossing situation (the 10 'o-clock vessel being the give-way vessel).
I'm not sure a lot of operators can tell the difference between 10:00 and 11:00, especially at a distance. So all I'm saying is you're in doubt take evasive action.
What I love about this board is that when you post a comment about something you think was someone elses fault, some people want to see if they can make it the posters fault. I guess that is human nature.
Let me be clear, at NO time would I have risked hitting the other guy just to prove I had the right of way. I would have moved long before it became an issue. In this case the other boat changed heading before I needed to do same, just as I would have expected him to based on the rules. The question arose when he decided to take my stern so close. In looking back to see him, I saw him raise his fist in anger at me indicating he did NOT think he should have had to change course. Hense my ORIGIANAL QUESTION: How could someone be so sure they were right as to raise a fist in anger after having spent even a little time on the water?
I NEVER ASSUMED anything about this guy or any other vessle on the water. I am responsible for my crew and boat. I don't rely on anyone else, particularly those I don't know. But the term STAND ON is used for a reason. You maintain course as that is your responsiblity until you feel that doing so may endanger your craft. It NEVER go that far, the other boat changed course.
I think changing course when the stand on vessle, only creates confusion for other boaters and is no less "wrong" then not giving way. If I jam on my breaks at a 4 way intersection when I dont have a stop sign in my direction just because I "thought" the guy coming at me from the right "might not" stop then that would be poor driving. I could get rear ended by someone or spook other drivers. ASSuming all boaters are idiots is as potentially troubling as assuming they know what they're doing.
Prospective,
I understand you being the Stand-On vessel, but I think you let this idiot get to close to you and your daughter without taking evasive actions. In hind sight you could have pulled back on the throttle, turned to starboard, given a horn signal or hailed him on the radio but you chose to be the Stand-On vessel, which is OK this time.
You asked "how could anyone spend a week on the water and not learn this basic rule by accident", well thankfully you and your daughter were not his instructors. Maybe the next time someone will get his registration numbers and notify the proper officials.
Good Luck,
L.C.
"You can be right or you can be dead right"
Originally posted by el sea
Prospective,
Good Luck,
L.C.
el sea, with all due respect, I did not choose to be the stand on vessle, I was by nature of the circumstances. I guess, if anything, I choose to follow the rule. Had I gotten to a point, in my judgement, where changing course became necessary, I would have done so as I've had to in the past. I've tried to make that clear. I guess you disagree with my judgement but the benefit of the doubt would be appreciated.
I'll admit, the horn signal may have been appropriate and will certainly consider that next time.
"understand you being the Stand-On vessel, but I think you let this idiot get to close to you and your daughter without taking evasive actions. In hind sight you could have pulled back on the throttle, turned to starboard, given a horn signal or hailed him on the radio but you chose to be the Stand-On vessel, which is OK this time.
You asked "how could anyone spend a week on the water and not learn this basic rule by accident", well thankfully you and your daughter were not his instructors. Maybe the next time someone will get his registration numbers and notify the proper officials."
LC,
you don't choose to be the stand on vessel, you have no choice. Deviating from the rules before it becomes apparent the other vessel is not taking appropriate action can sometimes make matters worst. Imagine if he had slowed down and turned and be rammed over the stern by the other guy ?
"give a horn signal" ? the only appropriate signal there is 5 blasts... however, do you really think the other guy would have even heard it over the sound of his engine, on plane with the wind? I doubt it.
Radio ? how many sunday boaters are on 16 ?
To be honnest, I'm not a full boat length AT THE STERN is that dangerous... across the bow, of course, but behind ? a little close, but he's the one getting the wake. There are no minimum separation in the rules... if you're crossing behind, a boat length is fine.
the waving on the other hand is another issue...
"To be honnest, I'm not a full boat length AT THE STERN is that dangerous"
IMHO... I Agree and a very good point.
I've been in that situation with idiot boaters in AZ. Twice in one night. I maintained my "stand-on" stance until I determined it was no longer prudent and chose to deviate from the rules to save my arse. Sometimes you gotta do what you gotta do.
I have seen many responses talking about the 5 blasts of the horn...most boaters do not even know what 5 blasts mean (or any other sound signals, for that matter)!
Hail on the radio? In that situation, I don't think so! Every so often I hear a hail like that on the radio: "To the boat on my left, slow down!" Uh... care to be more specific? I pick up hails originating anywhere from Baltimore to Hampton, sorry, not sure who/where you are! Duh!
And that's if you can get a break in between "Radio check, Radio check".
We spent Sunday out on Lake Maurepas this weekend just anchored enjoying the smooth waters and slightly cooler weather. You wouldn't believe how close the big cigarette boats will buzz you. One pass us going about 60mph less than 50 feet from us. We were trying to figure out if he was going to hit us and if so which way we should jump from the boat. My luck isn't always great but with him it got better on his return path when he got one of his outdrives tangle up with a crab trap. I wouldn't have throught a crab trap could totally stop that huge speed boat but it certainly did. The Lake is only about six to eight feet deep in there and the only think I can figure is the trap was hung up on a log and filled with mud. Amazingly he didn't get out of the boat to get untangled. He kept backing up and going forward pulling with a lot of power. I kept hoping the trap would win and pull his outdrive off. But he got lucky and got away from it. I have tons of pictures of it while he was hung up with it. I would post one but I still haven't figured out how.
You didn't deviate from the Stand-on Rule; you applied Part 2 of it, as it was intended to be used. Read paragraph (a)(ii), and you'll see what I mean. It's to keep you safe, while you're still standing on.
Boating almost my entire life in the same waters as prospective I can tell you with almost certainty that
a) 5 blasts would get you either a blank stare or the middle finger
b) Hailing on the radio is useless unless you know the boats name, and then its very iffy if they
i) Have a radio at all
ii) Have said radio turned on
iii) Can hear said radio over loud music, engine noise, wind, etc.
I always seem to be the stand down guy where I boat, except fot the fisherman that crowd me.
Thanks boathandler. Maybe "deviate from the rules" was the wrong phrase. I most certainly understand part 2 and having a well-founded understanding of the rules and how to prudently apply them is why I can talk about it today.
YIP !!!
