Steamboat Coming!
Meuritt
anyone know anything about this?
B & W Steamboat Meet, at B & W Resort. An amateur steamboat club brings around three-dozen steamboats to the resort for a weekend of huffing and puffing around, a good excuse to exercise their steam whistles. It usually includes a parade and picnic luncheon outing to Tower Park or Westgate Landing, starting at 10 a.m. on Saturdays. Admission free, 916/777-6161.
Supposed to be this weekend
20 years ago a workmate had a steam boat and was part of that Steamboat meet. I assume it is the same group. When my friend was doing it I spent the night on the dock at B&W in my cruiser. The most interesting part was when Areneson and his go fast boat tied up next to me. Turbine engine boat on one side of me, steam boats on the other.
If you have an interest in steam engines it is an amusing thing to see but I wouldn't exactly call it a tourist attraction. Most of the boats are little open hull launches, perhaps 16 feet long. Their "parade" is a group cruise from B&W to Tower Park and back. Most of them eventually make it.
Watching these guys was enough to show me why steam engines died out so completely once internal combustion came along.
Rod
Rod, I agree, but they are neat to watch.....going back to another era for sure!
My friend gave me a ride in his boat. It had a single cylinder steam engine and a wood burning boiler.
Single cylinder steam engines have some significant issues. Number one is that they will operate in either rotation and there isn't anything other than momentum in the flywheel that makes them rotate in the direction you want. If the piston stops in either Top Dead Center or Bottom Dead Center it might not start turning at all.
To get going he would open the steam valve just a little and then give the flywheel (which was exposed and very large) a kick in the direction he wanted it to rotate. Once turning he could open the valve to get power.
No transmissions in these boats. To back out of a slip you start the engine going in the reverse direction, stop, kick the flywheel the other way and open the steam valve again. While steering (tiller) mind you.
Every so often he would have to feed the burner another piece of wood. The burner was just at arms reach from the tiller so he could do this without letting go of the tiller. The main supply of wood was up in the bow, however, so occasionally he would have to have a supply brought to the back. While I was with him that was my job, and I haven't figured out how he did this when he was cruising alone.
When he opens the door on the burner flaming coals would fall out. Twice we had to stomp out the fire burning on the wooden hull. Not sure why he didn't have something fireproof under the burner door.
Steam exiting the engine ran through a length of pipe laying in the bottom of the boat, which he referred to as his "keel cooler". This condensed the steam back into water and then it dumped into a tank towards the back. A pump driven off the prop shaft could be engaged to pump the water back into the boiler. Several problems in this boat: the chain connecting the prop shaft pulley to the water pump kept jumping off so he would frequently have to put the chain back on (without stopping, mind you).
Not all the steam condensed back into water and was lost to the air. The engine itself leaked like crazy, water dripping out all over. This required a small amount of bailing. We are talking about a bucket, no electrical system on this boat.
It also required replenishing the water tank from time to time. I was horrified to see him scoop water out of the delta to pump into his boiler.
These steam boaters really like to use their whistle a lot. I had the impression that some times it was because the pressure was building up too high and he just wanted to avoid having the safety go off. Other times it was just for show as the whistle blast would drop the pressure so much that the engine slowed considerably.
Between kicking the flywheel, stoking the fire he wanted, stomping out the fire he didn't want, putting the chain back on, engaging the water pump, adding more water to the tank, watching the pressure gauge, tooting the whistle, bailing and steering it didn't leave him much time for other things. Like watching where he was going.
Good thing the boat only goes about 5 MPH.
Watching a dozen of these boats all leave the dock at approximately the same time was as sight to behold. Think bumper boats. Not to worry, a dab of paint and all is well.
I think I really insulted my friend when I suggested that a small battery would power an electric bilge pump and the boiler could be fed off propane. Electricity? Propane? Wrong era!
Rod
I don't know much about much of anything, but I know this. Yesterday morning I was driving by B&W, and there was a boat trailered across the way, with what looked like a large BBQ mounted midship. I said to myself, FindMe, that's a steam boat. You see, gas boats have propane BBQ's. And they're not midship. That much I know.
FindMe
I went and had a great time from 9 when we arrived to when we drove up to watch some of them come in at the picnic area near Terminous.
I sat on the end of the gas dock and got videos of most of the boats going out, I will post to youtube when I have time.
I thought the same about the bilge pump. Talked with one guy about navigation/gps. wanted to use handheld and a laptop. I thought a handheld like my 76CSx was good for 5 plus hours, but the laptop's I have experience with are two at best.
Time to think about a steam generator, if loco's could have them, why not steam boats, and then there is the bilge pump.
Or just an8D or so, charge it with a solar panel on top of the ubiquitous canopy.
When I get the photo's posted, I will post the links here
San rafael
