steering wheel on 2004 36 sport sedan
RiskyBusiness
Anybody ever take the steering wheel off?
I need to replace mine and after taking the nut off of the shaft in the center of the wheel - it does not seem to come off. It doesn't seem as though I should be able to pull it right off because I can see a key whole with what appears to be a key going cross ways. Anybody have any advice?
Thanks!
The key should be longitudinal with the shaft, and it will pull right off (with some force), but keep the nut on a couple of threads, or your chin will be sorry. They "stick" for some reason, but should pull off.
slight tap with a hammer usually does it as well. what kind of wheel are you replacing it with?
