Stern Drive and Cable Install
NO GIN
So all of my fans out there know I need to adjust or replace my drive shift cable prior to re-installing my drives.
I have 2 questions:
1. Can I move out of forward gear with drives off to check/adjust cable in Gimbel Housing?
2. Do I need an alignment tool or any other special tools to re-install my drive unit?
Thanks!
[:-banghead]
Disregard # 2 I found that answer in the manual. However no where can I find if you can or should shift through the gears with the drives out.
Joe,
Questions like this will play better in the Engines/Electrical Forum.
I don't think there's any reason why you cannot run the helm control through all its modes with the drive off. BUT!!! Both Drive and Shift must be in Forward when you go to reinstall the drive.
Originally posted by j-d
Joe,
Ok great, thanks. Will post questions like this in the other area from now on.
