OK, I found a shop that does bead blasting on stern drives.... so I will probably have him strip and then I will recover using alodyne, primer and merc black this fall... followed with antifoul in the spring before launch. Couple of questions.... the holes for the sea water pickup... I had barnacles on the holes this year and scraped them off.. but no doubt some of the pieces fell inside the drive where the water is picked up. Is using a vac to suck them out satisfactory?
The bead blaster guy will be sealing those holes off. How do I prevent barnacle growth from occurring inside that area and how do I check to see if there are barnacles inside that area?
Is there any reason to separate the drives before blasting? Raw water impellors were changed this past summer so they don't need to be done again. OK to blast (and paint) as an assembled unit?
Alpha 1 Gen 2
--Rick
Alpha 1 Gen 2
--Rick
