Sterndrive--up or down?
JB Fan
What is the proper way to stow an outdrive while docked in salt water? All the way up in trailer mode or all the way down?
Thanx, Garry
If it was mine, I'd leave it down so not to stress the bellows,
Unless it can be totally removed from the salt water, as in the old OMC drives, IMHO it likely doesn't make a lot of difference. Do you want 1/2 or 3/4 of the drive corroded?
Keeping it full down also prevents barnacles from growing in the folds of the bellows which could cause cuts and subsequent water intrusion. Besides how much of your outdrive actually gets out of the water even in trailer mode? My props don't even come out of the water in trailer position.
Here is a view of my drive after last winter in salt water in the up position. This year I leave it in the down position:
Always leave it in the down position whether it is on the trailer (except when towing) or when in the water.
Thanx for the advice, everyone!! The guy next to me said to leave it up. I didn't think that was right, but I just wanted to be sure!
Garrry
Down is always better. The bellows will have tension on it all winter, and that's not a good thing.
Jimmyboy
