- Jun 25, 2006
- 21965
- 99
I have a friend that has a 2003 Chaparral Sig. 300 5.0 Mercruiser/Bravo Three outdrives that has top mounted shifter/throttle cables that are really stiff when shifting from forward and reverse. So much though that when docking you have to pull real hard and this makes the response time slow. The dealers mechanic said that this is normal for a sig. 300 because of all the bends and turns in the cable. They have replaced two of the three cables (cable in outdrives not replaced yet) and have adjusted the the friction brake as loose as possible. What would be next?
Thanks in advance.
Thanks in advance.
