Stratoglass/eisenglass alternatives?
rikki
The stratoglass on one of my windows on the flybridge of my Jersey split horizontally. I have kept up with the cleaning and maintenance of it. I live in Florida and can only guess that the extremes of cold mornings and hot afternoons we have had this winter must have had some effect because when I went to roll it up, it split. Does anyone have any information on any alternatives to stratoglass or eisenglass? Any new products out there? thanks.
How big is it? Can you just hinge it pull it straight back as if it were a pane of glass?
Rikki,
I had replaced my eisenglass with strataglass 2 1/2 years ago and instead of rolling up, I zip it to my canvas bimini. The area was reinforced to avoid undo strain.
After 2 years, the strataglass hazed and scratched and I have now replaced it with Makrolon AR polycarbonate, which can not be rolled, therfore I will zip to canvas bimini also. You can check there website for information.
KElly,
The polycarbonate is the perfectly optical stuff ?
It is hard to beat lexan type polycarbonate. My windows fold up towards the center of the bimini. Glass clear.
EZ2CY is a well known brand used.
Mine is 9 years old and is holding up great.
Isinglass should never be rolled if you want to keep it clear. Remove and store each panel flat, preferable out of the sun. I put mine on the bunk when I need to have them off.
In the summer, I remove all the curtained panels and bring them home. I have custom made screens which go in place of the panels. In the late fall, I switch out the screens for the curtains again.
I use EZ2CY as clears on 3 sides between windshield and hardtop ( with Stratoglass only for aft rollup curtains on my express), and it is a great rather pricey acrylic product that holds up extremely well. It can't be rolled up so accommodation is usually made to swing up and secure. I just leave mine installed full time. It's about 10 yrs old. Highly recommend the stuff.
LOWER HELM!
AC/Heat Defroster ;-)
Ive got to admit that Andy seems to have great visibility from his lower. Many lowers I've seen you cant see over the bow. Unfortunately his windows seems to obscure the palm trees, what's up with that??
one of our boat lines is now using Lexan for their enclosures. It's really clear and fairly easy to keep clean.
No problem seeing the Ice-Eaters this time of the year
My canvas guy was able to use 40 mil lexan at the corners and 60 at the flat windows. Now I have no wrinkles and perfectly clear windows everywhere including corners. Curving the 40 mil lexan adds rigidity to otherwise very flexible sheets.
We have the rear of our aft deck enclosed in EZ2CY. Three very large and two small panels. Tremendous optics. You have to maintain them with the right stuff (210 or their proprietary brand) and be careful in handling them. I cracked one of ours while trying to swing it up over a piece of furniture to its twist holders mounted on the ceiling. They also get little scratches and smudges easier than I would like. Highly recommended, but you have to commit to proper ongoing care and handling.
George
Hatteras 56MY
Two comments: 1) Stratoglass is nothing more than eisenglass (DP clear pvc)with a scratch resistant coating. 2) If you got the $$$; EZ2CY is the way to go.......does not roll up !
I think other brands of rigid plastic lexan type are cheaper than EZ2CY
So if you want something that you don't have to worry about maintaining, other than a regular cleaning, what would you guys recc.? I have a fishing boat and am more concerned with fishing than being careful not to scratch my curtains. And I HAVE to be able to roll them up. So in this situatuion, what is recc.? Mine are OK for the moment, but I suspect I'll have to get new ones next season.
JB
I'd say Strataglass of the stuff I've been around. As for "not worrying about maintaining" no such thing. If you don't maintain you will be dealing with blurs and scratches with any of these solutions.
EZ2CY is somewhat flexible, not rigid like the lexan I have seen. You see it used fairly frequently on high end sport fisherman; swinging it up and attaching it to the underside of the hard top or bimini is fairly simple.
George
Hatteras 56MY
Here is an example of lexan used to create a hardtop like enclosure. Note the curved window in the lower picture is glass clear and wrinkle free.
