Stuck In Gear
rooengine21
I am new to boating and I bought a 1991 19foot Chapparal Sport. While out on the lake the other day, my boat became stuck in forward gear. When the shifter is in neutral or reverse, the prop still moves forward. Any suggestions on what is wrong? Shift cable bad??? How much to repair this? Thanks for any advice!
Josh
Sounds like linkage came loose, cable broken. Are you running Mercruiser or Volvo power? That could make a difference in the repair or diagnostics.
What's it powered with? Make, Cylinders, HP and Drive Type if it's an I/O...
Most likely a bad shift cable. As in it broke, or possibly just became unattached.
The usual configuration of the shift cable is that it "pushes" to get forward and "pulls" to get reverse, or out of forward. When the cable breaks inside the housing it can still push, so you can still get forward. The "pull" doesn't work, and thus you are stuck.
You should be able to confirm this by observing the linkage at the outdrive where the cable attaches. Have someone operate the shift while you watch. You might as well dig into whatever you need to as the probability is very high that you will need in there to replace the cable.
Once you have convinced yourself that you need a new cable you can save yourself some trouble if you go about it right. If you can establish how long the cable is without removing the old one then the easist thing to do is to tape the new one to the end of the old one so you can pull the new one in as you pull the old one out.
If you can't do that then attach a small rope to the end of the cable and pull that through as you pull the old one out. This will help you pull the new one in.
When you go to buy a new cable you may find that there are several different grades of cable. The primarly difference in the cable grade is how sharp of a turn they can make and not bind up. If you have a relatively straight shot then it doesn't matter much, but if the cable needs to make a tight radius turn, buy the more expensive cable.
Rod
Be glad it wasn't alot worse. Last Sept. on my 2000 27 ft. Searay I was pulling out of my slip when the shifter cable broke. By the time I realized what had happened & killed the engine my swim platform was already ramming into the bow of an adjacent slipholder.
My insurance paid for the fiberglass damage to both boats but refused the mechnical repair of the shifter cable. Between the deductable & the shifter repair work this was a very expensive mishap. I'm certainly grateful at least no one was hurt.
Hence, if you didn't hit anything else i.e. boat, dock, channel marker, etc. you're very lucky.
I will check the cable out and get back if I have any other questions. Thanks for all the help!
