Mineral oil sounds OK, I never heard of it before.
Anti-freeze is used on the Ice in the winter for Ice Fishing. You dig a little dwell in the Ice, put the transducer face down in the Anti-freeze and you can see just fine.
If you do a through-hull....you must have a turbulance free zone in front of that transducer face.
The Hull must not have any roughness of any kind, in front of the transducer because the turbulance caused by the Barnicals/rough surface will cause your Sounder to lose the echo about 10-15Mph.
Also...the angle of the Transducer wont mean too much at low speeds, but at higher speeds the angle of the hull will raise up, and if the transducer is plumb vertical while the boat is still, it will be advanced about 10 degrees at speed.
Also, you might (Will) lose the echo if your boat has a list at speed. Trim tabs not working well might allow the hull to list 10 Degrees and you will lose the echo very quickly. The closer to the Keel, the better.
However you want to stay about 30" from the outdrives and if it's under the engines you will need some pretty skookum shielding. Better to go out in front of the engines a bit.
