Summer vacation trip
Moderator
Trip is booked!
July 2 - 3: Bowline (Hudson River) fireworks
July 3 - 4: Navasink River fireworks
July 4 - 7: Schooner Island Marina, Wildwood, NJ
July 7 - 11: Baltimore Marine Center
July 11 - 14: open to spend in northern Chesapeake
July 14 - 15: Utsch's Marina, Cape May, NJ
July 15 - 17: somewhere along NJ coastal waters
July 18: Home (boo-hoo)
July 11-14, try anywhere on the sassafras, rock hall or worton creek
Have fun
Tom
Tom, those are the areas we are looking into.
Hogan,
If you have not been to Annapolis you need to go there. It is very close to Balt. and has allot to offer. It is on the top 2-3 to see on the Chesapeake. most of the other ports mentioned on the upper bay are extremely quiet with not much to do.
my .02 cents
Hogan,
I also see that you chose the Baltimore marine center. I hope you chose the Baltimore Inner harbor marine center? They are both owned by the same co. but are miles apart when seeing Balt. The one I am talking about is right inside the Inner harbor and walking distance to everything. The other is not near any of what you would want to see. Let me know if you have questions.
Looks like a great trip; might be a little late for suggestions since everything is booked - but if after close to a week on the Bay your teenagers start to get bored, you might consider a run up to Philadelphia Marine Center for a night. It's about 40 miles out of your way, but the marina's are right in the historic/tourist part of the city - plenty to do on the Bay without heading that far north - but you'd be very close to the cheesesteak place; don't you owe one to Mikeeh as a result of the world series non sweep?
Assuming you spend those days on the N Bay - consider leaving Baltimore, and stopping in Rock Hall for lunch at Watermans - then spend that night in Fairlee Creek. Next night Sassafrass or Bohemia, then off to Cape May.
How far North do you want your last Jersey stop to be? I always liked Avalon, Sea Isle City, and Margate. Unless AC is your thing; I was never a big fan, but definitely see the attraction. Four bucks a foot is pretty brutal though.
Wow Hogan, we have the same trip planned except we added,
July 11 - 14: Herrington Harbour South
Looks like our paths will be crossing! ;)
Really looking forward to exploring a new area. Since we are only scratching the surface we are already looking at next years plans for a longer trip down there. How about Down the NJ coast to Ocean city, down to the southern entrance of the Chesapeake and work our back up through there.....
We chose the Baltimore marine center because of the pool there. The water taxi can ferry us into the innner harbor, so we should be fine.
We are thinking of renting a car to drive to see Annapolis for a day.
Hogan,
Some things to be aware of in Balt. I am not sure the water taxi stops at the BMC, you will need to check on that. They have about 6-7 stops that they make and do not change their course. Also, the water taxi's in Balt. are kind of a pain, they may not service your area late at night. Some stop earlier depending on the route. You may have to wait quite a while to get one and then switch to get where you would like to go. It can be a process. They were $9 last yr. for an all day pass, not sure what it is this yr.
Is a pool that important? I saw where several of your stops have a pool. Balt. is a fun place but much easier if you can get in the areas where you wont have to worrry about getting back and forth. There are a few other places that do have pools and are a little closer to the action but are still kind of a haul.
The Anchorage marina is a little closer, has a pool but still kind of away from things. Personally we like the Inner harbor East marina. No pool but is in a safe area, gated, restaurants, aquarium, HardRock, ESPN Zone, movie theatre, grocery store. All within a ten minute walk. We are actually headed there for the 4th of July.
I may also be running into you guys down in Cape May/ Wildwood area. No definite plans yet, but the admiral and I were just talking last night about a 4th trip down the coast......
I hope to be in the Broughton Islands for a couple of weeks this July.
Dave N
Hogan has probably already checked out the specifics but he would get on the ferry loop that comes to Ft. McHenry. I know it stops as Capt. James landing and maybe another canton stop but it wouldn't be a long walk You would have to transfer to the other ferry in fells point to get downtown. Worse case scenario is you pay $15 to catch a cab when the day is done if the ferry isn't still running.
A couple of tips Barnegat's North Jetty is underwater at high tide a couple of boats get lost there every year, Little Egg (Holgate) is shoaled bad out to almost 3 miles on the North side SeaTow escorted a sailboat in last weekend, Townsends inlet between Strathmere and Southern Ocean City is all but closed. Waretown and the Point Pleasant Canal have working dredges. I believe there is also a working dredge in the Cape May Canal. The South Jersey shore took some major storm damage this Spring. I'd recommend staying outside as much as possible from Central Jersey South or call SeaTow and ask for assistance.
I'd love to follow or lead if I can take the time off. Mike no shortcuts this time if it's a blowout tide.
Sounds like a great trip guys.
We may have to reconsider and stay at the Baltimore Inner Harbor Marine Center - we can use the pool at the other Marine Center...
rommer?????
Not sure Hogan. Is the "gated" thing mean it's in a less than safe area where walking the dogs could be an issue at night?
Check the web site, the amenities page at the inner harbor marina says you can use the pool at some nearby hotel.
Looks like all of them are "gated".
Can you walk to the Inner Harbor from BMC? If so, how far is it?
Not only can you use the hotel pool, but you can use the pool at BMC.
You want the gates, keeps the Micheal Jackson types off your boats.....................
Hi HOGAN,
My wife and two teenagers will be in Wildwood for the first time from July 3rd to 11th. We are driving there on the 3rd and have rented a condo. for the week. I will keep an eye out for your boat and if I'm lucky enough to see you, I'll stop and say "Hello, eh?".
Take care and enjoy your vacation!
Brian
