- Dec 6, 2005
- 19709
- 190
Broker's advice:
Do the boat survey without an engine analysis. The CAT diesel engines are still under warranty and only have 150h on them with an in service date of April 06 and a full warranty for two years (expires April 08).
Broker reasoning was that an engine analysis was necessary but do that later just before the warranty expires. Since the warrantied engines are good thru March 08, do the engine analysis later rather than earlier. Come March , get CAT out there to do the pre-inspection for the extended warranty and get the extended warranty end of March.
Anything that comes up between closing and April will be covered by warranty.
I would think the engine survey now would be the same inspection/analysis procedure as the one done for an extended warranty. It seems to me I am gaining a few months of warranty, but may be missing something here and wondered if any of you have been in this situation and what did you do?
The boat and engines were sea trialed and all data recorded by the surveyor appeared good.
