Originally posted by Philyteach
Just remember that you are going to have less weight and friction to stop you from moving with the wind force against a kite or balloon. You could be dragged miles away from where you are expected to be in just a mild wind.
That's some food for thought. I wonder how much a balloon like that could move a person in the water? If it's significant, I could easily see that being an issue.
Consider initial action searches are generally a drifting pattern where the primary search object is a person in the water - therefore they're oriented in the direction of drift with no regard for wind (a person in the water is not effected by wind, just total water movement). This is usually determined by a field expedient datum marker - often a simple life ring and strobe (the highly accurate self locating datum marker buoys are great for large scale extended searches, but impracticable for the initial search). These patterns are run with a track spacing of 200 yards, with the first leg oriented down drift. So, the most common drifting pattern, a sector search (VS), would have a total search area encompassing a 400 yard radius, and each subsequent VS would cover the same size area, only it would be re-centered on the new datum (marked by the current position of whatever was used as a datum marker). Common search speeds are 6 or 10kts, so at 6 kts you're looking at a 9 minute pattern.
So in 9 minutes you're covering that 400 yard search area. Second pattern would be offset 30 degrees from the first, so it doesn't seem it would take a significant amount of movement from an unexpected force in an unexpected direction to pull that search object out of the reasonable search area.
Especially if datum was not established with a high degree of confidence, and the initial pattern is an expanding square. Think of a series of concentric squares. The larger the squares get, the slower the rate of creep is (the rate at which the search area in this particular pattern expands). If an unexpected force is moving the search object in an unexpected direction at a steady rate, it will be moving out of the search are faster than the search are expands.
