Swim platform
Britanic
My 1988 34C Silverton has a bolt on platform. Its comprised of 6 stainless brackets bolted to the transom. The platform is basically a flat fiberglass board, no coring except where it mounts to the brackets.
It is starting to delaminate and a couple of the mounting blocks are soft. Anyone have a good source for a replacement (platform only). I just got a price from the yard to refinish and I think its high.
as long as the transom mounting is solid, you could have a nice cedar or teak deck to your design.
i bought a swim platform for my sundancer from swimplatforms.com out of AZ. they did a nice job. it was not cheap though. i would be surprised if you could get a new one for cheaper than they could refinish the existing--especially with shipping. good luck
Also, if it is easy to remove from the boat, you may want to take it off yourself and take it "inland" to a fiberglass shop. They tend to be a little more reasonable, and you wouldnt be paying the yard 60/hr to remove it and reinstall it.
While you have the swim platform removed, triple check the areas where it was bolted to the transom for water intrusion. If there is any damage, get that fixed prior to affixing the platform back onto the transom......
Thanks. The brackets are bolted to the hull (solid no core) and the platform is bolted to the brackets. Very easy to remove. I will try some others as suggested. I could also tackle it myself I think. The mounting blocks can be easily cut out of the bottom and new ones reglassed in - nobody would see that so doesnt have to be pretty. And there is some pretty durable glue down foam grip pad available out there I could use to cover the top...
How good are you at building things? New platform will be at least a couple Gs. Built one myself, with help, a few years ago.
Foam core, cloth, resin, Awlgrip plus other materials were $600 or so. Building a platfrom is very labour intensive & messy so you will need lots of time & a room to build it in.
Britanic;
A few years ago I got a fiberglass platform from Butler Marine in Pa. I don't remember the cost specifics, but it was around $2000.00.
eric
Great info as ussual.Veebes, dont think I am the right guy to build one myself, the price I recieved to refinish what I have was $2,100, and in my opinion the condition is not that bad to begin with and is a simple platform. $2K for a new one seems reasonable. I am going to call the marine connection first, seems like a great find.
When I removed mine to refinish (teak) I replaced the wooden backing plates with Starboard.
Also, check the bonding system as it needs to be attached to each and every one of those stainless brackets.
