T-connectors Ford Explorer
john gov.
I thought this was going to be the easy part. To complete the trailer hook up I need a T-connector so that I can plug in the Explorers wiring and connect to the boat trailer. I keep finding connectors that fit 1995 to 2000 and others that fit 2002 to 2004. Problem is that mine is a 2001.
Anybody know anything about these little buggers?
Thanks for any help,
John Gov.
I have a 2001 mountaineer....same thing. The harness is pre-wired. All you need from ford is the pigtail. The plug it connects to is under the rear of the vehicle. If you need a picture, I can send it to you.
Chuck, thanks for the tip. I just checked under the Explorer and there is a round female socket with a red rubber protector cap on each side of the vehicle. So I need the adapter that plugs into each of these two sockets? Is that available from a Ford dealer only? U-haul didn't have what I needed this morning, Auto-Zone has something they would have to order(same as Reese part #118345) but the picture is not clear; looks like there is some sort of module and a bunch of wires.
U-haul was convenient for the hitch , but now what?
John Gov.
Stan, Yes I got the class III hitch installed this morning at U-haul. Cost $188 with tax and they did a nice job. The electrical adapter has me stumped though. I just came back from Pep Boys and they had the adapter for the 1995/2000 and the 2002/2004 but none for my 2001. Think I'll check out Trailer Boating.
John Gov.
Cool John! Your almost there. You'll have a nicesafe rig when your done.
Living for Spring...Stan
I can't believe how much of a PIA this has become. I went to the trailer hitch specialty shop here and bought a Hidden Hitch part #16241 for $12.95. It plugged right in under the left corner of the truck but NOTHING! I checked fuses, tried with the key on, double checked my test light and NOTHING. Still wondering why I have two plugs under the truck (left & right corners).
Went to the Ford dealer, they printed out a drawing and it says Explorer plug is on left, Ranger plug is on right. Still wondering how come I got both? I did try the right side but the notches in the plugs don't mate there.
This was a new truck in 2001 and never been touched.
Any Ford Experts here?
John Gov.
Well I finally got it done. Seems like everything before and after 2001 was an easy hookup. I had to get the kit that had a little black box, had to tee into three locations behind the drivers side taillight, another behind the right side taillight, then run a wire back to the positive terminal on the battery, and drill a small hole to secure a ground wire. The kit looked a lot worse than the actual task. Actually everything I needed was in the kit and required no splicing of wires. Everything just snaped together.
No if all goes well I will bring my new-to-me 2003 Sea Hunt Triton 232 home this Saturday.
Wish me luck,
John Gov.
Congratulations on a successful project and especially on a new boat!
Where do you get the kit? I have a 2001 Ford Explorer that I will be towing with for the first time this spring and it sounds like this is one runaround that I don't need to do.
The kit was a Hidden Hitch part #16395, should be available any place that sell trailer hitch parts. Reese and Draw-Tite should also have one. Good luck,
John Gov.
