Tachometers fluctuate, sync stops working
WDMagic
The tachometers on my 1987 30ft Sea Ray Sundance fluctuate from 200 to 1000 rpm. At times the port tach will read correctly and the starboard tack will read 200 to 1,000 rpm higher. Other times they reverse and the starboard will read correctly and the port will read 200 to 1,000 rpm to high. Because of this I always use the sync gage to sync the engines. Recently the sync gage stopped reading the port engine.
Is there anything I can do to correct the problem other than spending $300 to $400 dollars to replace the tachs and the sync gage?
Thank you for your help.
WDMagic
Look for loose and corroded wires and connections associated with the functions. Also check all the major ground points associated with the dash and it's connection to the common ground on the boat.
Thank you for the direction. I will check all connections and grounds.
WDMagic
