Tandem axle Trailers
CheetahBoat
I was wondering if trailer axles are soppose to lean inward..The front one is ok and looks right,Its the back one that leans inward..is this a common issue? My unit weights over 2000lbs..Any help on this topic would be appriciated...Thanks...[:-viking]
Not to my knowlege. I have not noticed this on double or triple axle trailers.
Not sure what you mean by "lean inward".
Lean inward from what view? Are you talking about a curve in the axle from level to down?
The correct term for that which you describe is "camber". It ain't supposed to be on trailer wheels.
Two thousand pounds shouldn't require two axles.
If you tires are leaning inward at the top I would suspect a bent axel. A long straight edge will tell the tell .terry-==tboss
If your tires leans inward when turning, it's normal on tandem axle, but if they are leaning inward while going straight, something not right.
Pretty much finished rebuilding my trailer. As usually happens with most projects, you end up learning more than you ever wanted and how barely adequate some things are made(not only trailers).
Recently, trailers have been mfg with some(slight) camber-in(bottom in)...at least that's what I've been told. I actually don't see the need for it. I've always felt camber-out was more stable and cornered better(as far as cars go).
You'd probably be better off asking a trailer manufacturer.
