Tapping into fibreglass
GrecRI
I'm replacing a hatch on my 1985 Sea Ray Weekender. Unfortunately the holes in the new hatch frame don't match up with the holes in the old one. So, I filled the old holes with Marinetex and smoothed it all out.
The last hatch had been screwed down with #8 wood screws, so I planned to install the new one the same way.
I thought I'd drill through a small amount of gelcoat and glass before reaching the wooden core of the deck, and that would be what held down the screws. To my surprise, the deck in that area is almost solid fiberglass.
I drilled a pilot hole and then chamfered the top of the hole, but the rigid fiberglass doesn't seem to be very 'wood-screw-friendly' for lack of a better term.
I'm wondering if anyone here has ever tried performing an installation like this using a drill and tap with machine screws instead of wood screws. 8-32 screws would fit through the frame holes fine, and I could easily tap the fiberglass, but I don't know how well it will hold the fine threads.
Yes I have many times, in fact tapping out fiberglass is better than using wood screws from what I've been told. For small fine thread screws you would not even need to tap the holes I would think.
My new Novurania came with machine screws holding the console onto it's base. As I recall, there were 11 of them. At first I thought they had used a captive nut on the inside but upon further examination I saw that all eleven holes were tapped. The machine screws hold well but lining up the trim, the console and the base proved challenging.
