Temperature not coming up
  • Thread starter Thread starter blouderback
  • Start date Start date
B
blouderback
Guest
Hi all,
I'm back from vacation down in Ocean City, MD. See here for some pictures and a fishing report.
Missed the channel once in the Isle of Wight Bay. Apparently, the channel had shifted and they put out a temporary nun that I didn't notice 'til it was too late. Anyway, after shutting down the engine and getting out into shin deep water and pushing, I was able to get off the sandbar. The next day, I noticed that the engine temp would not come up to it's norml 160 - 165 degrees that it usually runs at, it would only get up to about 100 - 110.
Did I damage something, like maybe a thermostat? Can I use a regular 160 degree automotive thermostat for a replacement?
That would be my first thought, thermostat stuck open.
I don't think you can use an auto thermostat.
When you get a chance, pull it out and see if it is stuck open. If it is closed, throw it in a pot of cold water with a meat thermometer, turn on the heat, and watch to see what temperature it opens at.
Great pics Bob. Remove your thermostat (pay attention to which side is toward the engine). Make sure there is nothing stuck in it keeping it open (I would expect to see something). Reinstall.
