If it is your waste holding tank once your hoses get permeated you cannot get the smell out. If this is the case replace them with good quality waste hose as suggested.
Two things I've found extremely useful when installing this type hose are hose cutters(sold at Sears in varying sizes) and a heat gun.
The hose cutters slice through this hose like butter and I even used one to cut anchor road loose from a fouled anchor with same result.
Use the heat gun on lowest setting being careful not to get the hose too hot, just enough to be malleable to go over the hose fitting.
As a side note, I have two potable water holding tanks that are interconnected with each other with 1 1/2" hose.
