Thru Hull - Can't Find
TurboWarp
Am looking for a 3 inch by 1 inch fully threaded nylon or any material thru hull. I can't seem to locate one. It is am OEM thru hull for my 1998 Sunbird Neptune 200 CC.
Any ideas?
Thanks....
Sorry that's 1 inch diameter by three inches long with nut. I found a brass one for $109.00. No way.
Thanks....
Above or below the water line ? What's it's purpose ?
I suggest if you use "plastic" , use very strong Forespar Marelon, never nylon which cracks or breaks way too easily.
http://www.boatfix.com/catalog/662.pdf (left bottom)
B/F price: CF 251 1 in. THRU HULL $12.51
FORESPAR 906014 / FRS906014
If you find a xducer that will work, no matter what size, you can use ABS to make a socket. Epoxy that down in place. Fill the bottom with some kind of "NO AIR POCKETS" (grease, epoxy, etc) and slide your Xducer down till its got no air down there at all.
The Guys who told me this, said it will work like that for Metal boats!
If any of you guys know different be sure to tell us because I'm repeating some thing I have not verified.
Not for Cored F/glass or wood though.
Please don't tell us that you would risk the sinking of a boat for want of a $109.00 piece of hardware.
OK all, thanks for the responses. The original below the waterline was nylon and lasted 12 years, but I found a bronze one at Westmarine in Annapolis for $45.00. Just got back with it. So I have upgraded. The thru hull is for my livewell.
Thanks again...
nylon does not belong below the waterline. Are you sure any mfg actually put in a regular nylon thru hull below the waterline? Marelon I would believe, or nylong above the waterline.
If it really was regular ole nylon, I would strongly recommend checking the entire boat for other mistakes.
You should make sure that your bronze one is properly bonded, otherwise galvanic corrosion can eat your bronze. It could sink your boat.
Ghost,
I am not really sure it was nylon. It may have been Marelon. How can you tell?
Rob,
I have a center coonsole outboard. Do you think I still need bonding? The thru hull is not touching any other metal.
Marelon is usually black in color, nylon is white or "natural" in color. Marelon is glass-reinforced nylon, usually with UV inhibitors in it.
Any metal fitting below the waterline should be bonded.
