Saying you don't know how to mix epoxy is like saying you can't use elmers glue. Directions are right on the bottle and simply a matter of using the proper proportions (1:1, 2:1, etc). Stir thoroughly and mix in small batches of a few ounces. That's it. That, and simply purchase a thickener which you add slowly over the course of no more than a minute until you get to peanut butter consistency. If you can't do this, you can't do anything. Walking to the curb to get the mail is more difficult if its raining outside.
If I were to use a product like 101, it would ONLY be where I had a mechanical fastener capturing the matrial. You should never use a product like that to just quirt in a hole. You could use a product like 5200 to just squirt in a hole, because it is designed as an adhesive/sealant and has the potential to tenaciously grab onto a surface. Of course, I still would not use it to squirt in a hole below the waterline as unless you have prepped that hole, you don't know if there is good material to grab onto in the first place and if you are going to the trouble to prep the hole, then it takes no longer to use epoxy, so there is no reason to use an adhesive in a use it is not really designed for (even if it "might" work).
BTW, for pure "sealant" uses, my favorite has always been 3m 101. Its availability has slowly decreased over the past 3 years or so. Is it just me, or did it suddenly become much harder to find this past season?
I guess this all boils down to whether you like shortcuts or not. Personally, every opportunity I have to remove a stainless fastener used below the waterline is going to be taken advantage of. Every hole in a boat is a liability. Use as many as you need and get rid of the rest.
