Tilt/Trim/Tabs
bmetros
I could use a little help in figuring out how to drive my used boat. I did take the coast guard class, but I could use some help driving. We went out last weekend and had a heck of a time getting her dialed in. I felt like a drunken sailor, bow up and swaying back and forth. I have tilt, trim and tabs on a 5.7 mercruiser IO. How should I start out? All down? Some up? and then how/what should I adjust?
Help.
Thanks all!
bmetros:
You could try this:
While at the dock, Run the trim tabs all the way up (Bow Up). Then time them for the travel all the way down (Bow Down). Do it a couple of times in each direction, to get an average, a median, or a repeatable time that you feel is reasonably accurate.
Set the leg tilt in the neutral position for starters. Then set the trim tabs in the middle of the run, half-way up/down, and get away from the dock into some open water. Say the travel was consistent at 7 seconds. Set the midpoint at 4 seconds from up/down. The key is: where are you going to set your throttle? The wind, wave, and tidal sea conditions will often dictate your throttle position. Safety, creature comfort, amount of other boating traffic, and fuel economy are factors. Experience will teach. (Very often, the pitch and decibel level of the Admiral's scream will assist you in selecting the correct correction to throttle position).
Once you are happy with your SOG (speed over ground) you can try nudging the trim tabs in either direction and noting the results. Say you nudge Bow Down for one second. Say this results in your RPM's dropping and the boat slowing. For this throttle setting, it ain't working out! Go Bow up for one second to get back to the middle position. Go Bow up another second. Say this results in an increased RPM and increased SOG. You are on the right track. When you maximize SOG and RPM for a given throttle setting you are running with good fuel economy, for those conditions of wind, wave, and current. Do a 180 and head back in the other direction and you will most likely find you need to readjust.
Then you can run the same process for the leg tilt, if you feel the need. If this works for you, let me know, and THEN I will tell you where I live.
That sounds like me the first time I took my first boat out! First, be sure to go idle/no wake speed until you are out of the marina and it is safe to get up on plane. Then you want to adjust your tabs for "Bow Down". This lifts the stern and you will get out of the hole faster. Then you want to give the throttle full power until you are out of the hole. If the boat's bow goes way up in the air and you can't see where you are going, something is way out of trim. Bring the throttle back to neutral and check your tabs, boat load, etc. You may have to move ice chests/passengers, etc forward to redistribute the weight on board. If you continue to have problems, you need to make sure your prop is in good condition, and it is the correct one for your boat.
Keep experimenting with adjustments until you find the right combo. Bow up and swaying back and forth is making your engine work the hardest [lugging]; and it puts out the biggest wake. If you don't have enough power to get out of the hole, bring the RPM down and take it easy back to port. Also a dirty outdrive and or bottom may be causing too much drag. There are lots of possibilities. Is there someone at your marina who might be more experienced and can advise you?
Good luck! You got the "theory" of boating in the safety class; now you need to learn the actual boat handling. practice, practice, practice!
PS, if you get out of the hole and onto plane ok, then bring the the throttle back some and put your trim tabs in a neutral position. You may have to adjust one side or another due to wind/wave action, but you want to settle your boat into a comfortable position for running on plane. Never run your RPM above the recommended redline and don't always have your throttle at full WOT. That just wastes fuel and wears out your engine faster.
Flutterby:
"All I'm looking for is a guy who'll do what I want, when I want, for as long as I want, and then go away. Or wait nearby, like a Dust Buster, charged up and ready when needed."
You have been running this naughty advertisement for quite a while.
Where do I send my application? Is there an empty slip near at hand with power? 15 amp oughta' do it. :D
Dear Old
You are the first to apply! I stole that quote from Maxine, the funny old lady. I have lots of chores at my house and on my boat as well on my RV that could use a man's hand! Are you still interested????
Flutterby:
Chores? Chores?
Mebbe I better go back and read that ad again!
I may need 30 amp power. :D
(S) OS
What in the world did you think I meant????? Are you just another Dirty Old Man????
Flutterby:
"Are you just another Dirty Old Man????"
Thank you for even thinking that.
I'm losing, aren't I?
In a general sort of way, the engine tilt is for adjusting the bow up and down, and the trim tabs are for adjusting the list ( side to side ). As you gain experience, you can expand the usage...
For starters, adjust the trim tabs to the fully retracted position ( extreme bow up ) and the "leg" to a straight up and down angle while at rest.
Get into open uncrowded waters then speed up and experiment with the engine tilt only, raising and lowering the bow. Use short pulses on the switch rather than "press and hold". If you go too far "bow down" you will begin to "bow steer" which is undesirable. If you are too far "bow up" you will "porpoise" or "bounce up and down" which is undesirable, so back up a little. In many cases, the desired angle is near the "porpoise" end of the range.
After you are comfortable using the engine tilt adjust the tilt to the "sweet spot" then, again using short, pulsing adjustments, experiment with the tabs ( only, leaving the engine tilt where you set it ). Note that as the boat "leans" ( lists ) to the side, the boat will tend to turn. Adjust only enough to get the boat not listing to either side. This is often all that is needed.
Many use the tabs to assist in getting on a plane. It can be done, but you should be comfortable with the rest of the process first.
As with most things boating, experience makes things easier/better.
Be safe, be happy.
This sounds like my first ride this past Sunday. I had a hell of a time figuring out how to get the boat stable and level. I would be listing port, adjust and now I was listing starboard. This definitely is going to take some practice.
"...I have tilt, trim and tabs on a 5.7 mercruiser IO..."
On what boat? If it is a 40' Regal, you are screwed. ;).
Tabs are a VLPITA at first. Once you get the hang of them, you will wonder how you ever got along without them.
I happen to run contrary to the CW being told to you here. That by no means makes me right, I just approach the problem from a different angle.
Indeed get the time from full up to full down and then back up. It may vary. Mine does. Additionally, measure each tab independently. I have a ~1 second differential between the full travel on the port and starboard tabs. Until I measured the travel time independently, I could never figure out the list I had at cruise. Drove me nuts for a season.
Depending on load, I take off in one of two ways:
-- with just the Admiral and me, I tuck the drive all the way in, tabs all the way up, and get on plane. Then I trim the drive out at one second intervals. When the drive starts to cavitate, I lower the drive for about one second.
At this time the boat will normally start to porpoise. I lower the drive in short (1/2 to one second) intervals until the porpoising stops. I now have the drive dialed in.
I now adjust for the port/starboard list caused by the aforementioned time differential in the tab deployment.
Hang tight, we are almost finished. Now I look at the GPS and tach very closely. In that I have already compensated for the tab differential, I am no longer concerned with that issue. I deploy the tabs in VERY short bursts.
This is what really threw me. The bow will lower, RPMs will decrease BUT my speed will increase. When I see the speed start to decrease, I retract the tabs one short burst.
-- I do basically the same thing with more folks on board, however, I just start with the tabs fully deployed in order to get on plane then fully retract them and go through the same process.
While it may sound like an all day evolution, it is not. The first time it took about 10 minutes because I was experimenting. Now that I am used to the process, less than a minute. I have increased my MPG / lowered my GPH considerably using this method.
HTH
If you are listing hard to port then starboard you might be adjusting your tabs too much at one time. Just tap your trib tab button when adjusting. Do not hold down the button. It will take a few seconds for the tab to adjust.
