Time for a Mechanic?
Philyteach
Some of you may remember that last month I decided to tackle the replacement of the water pump in my Alpha 1 Gen ii. I thought everything went well and it still may have, but I'm finding some discrepancies that are scaring me a bit. After the boat sat in the driveway for a few weeks I noticed some high performance gear lube under the transom. Not under the outdrive, but further forward right about where the bilge plug was. I had some tarps down when I removed the lower unit (and I know I spilled some oil) so I assumed that it was just mess that I missed cleaning up. Yesterday I trailed the boat down to my marina. The weren't able to launch the boat because they had a party and the ramp was inaccessible. I went to check on the boat today and noticed some high performance gear lube on the rocks under the transom again, not under the outdrive, which is in the fully up position. I got real nervous real fast. After cleaning up all the residue that I could find, including a big pool of it under my anode attached to the transom assembly I went home for a while. I decided to go check again after a few hours. I didn't see anything new, but some some reason I put my finger up in the hole (tube?) in the bottom of the transom assembly on the port side. I'm not sure exactly what that hole is for, but it was full of gear lube oil! Obviously there shouldn't be any gear lube oil there, but how bad is my problem?
Any ideas or suggestions would be great, otherwise I'll leave it to a professional.
Thanks in advance everyone!
Ken
Not really sure where you stuck your finger.
Do you have a drive oil reservoir?
Is the Finger Hole on the port side a match for one on the starboard side, where exhaust and water burble out when you flush the running engine on a trailer or wash rack with muffs?
J-D I was thinking it was the exhast hole, but I wasn't entirely sure. I've never run her up on muffs since I keep her in fresh water in a slip. Yes, there is a matching hole on the starboard side, but no oil in there.
jtybt15 - I have a remote monitor bottle in the bilge. It should pass through the transom somewhere near that spot.
You removed the whole outdrive, then separated the lower gearcase to access the pump, right?
The lube oil reservoir has a tube to the transom area. There's a check valve/kinda quick disconnect where the outdrive separates from the bellhousing (the steerable part of the transom assembly, where the upper outdrive gearcase bolts up on six studs). Starting to sound like something's amiss there, missing or damaged O-Ring, etc. I don't know how the lube oil tube gets to the bellhousing, or why the oil would appear at an exhaust hole.
Thanks j-d. I called my local mechanic and he came up with a few similar sounding idea: pulled the quick connect off and didn't seat it correctly or didn't notice it off, split an o-ring when installing or dropped one when sliding the unit back together. He's going to pull the whole unit off, pressure test and reseal whatever he finds. Hopefully it will be ready by next week (sigh).
Phily, I hear your (sigh), but isn't this much better then not discovering the problem until you have launched and are running along with family and friends? I think you dodged a BIG bullet!
Good luck with the fix.
Flutter's right. Since you never got into the water, you can't have gotten water into the gearcases. We just went through a similar case. Changed the pump and lube. Lube oil leak. Ours was the shift lever seal assembly. About a $20 part but it takes a couple hours labor, new OD gasket set, new lube (we'd had it running), etc etc. You might want to change that part. There was an update, but you probably have it. I think the original was white plastic and the updated one is black. Maybe vice... I can probably check on that. One of our AUX guys has two MerC OptiMax OBs and he changes that part every water pump change.
It was only by the grace of God that my boat didn't get splashed in that condition. I towed it from Cape May to Philly with every intention of launching it only to find out when I got to the marina that it was the opening of season party and the ramp was blocked with the band. A day earlier or later and I hate to think of what would have happened.
This is seriously dissuading me from attempting my own repairs in the future. If I can mess up such an easy thing as a water pump imagine what I would do to a real problem...
It helps to learn with an experienced buddy if you want to do it yourself.......
Phily - Had a similar problem last year, when the plastic (yep plastic) fitting through the transom broke, and all the gear oil from the resevoir leaked into the bilge. When I opened the bilge at the end of our trip to Long Island from NJ, I almost choked - thought the worst. In actuality it was only the gear oil from the up top resevior that leaked. Nevertheless boat was out of commission for a few weeks until the end of the season. Brought it up from Englewood to Stony Point very slowly on one engine - problem fixed this spring. Hope yours is as simple.
Like rummy said, there's a hose that goes from the drive to a plastic thru-hull to another hose. Any of these parts can and do fail. The thing is, I can't think of a reason for there to be drive oil in the exhaust ports of the transom assembly...unless it's engine oil instead.
There is a vague chance that large amounts of drive oil is backing up thru the exhaust cavity within the drive itself and showing in the exhaust ports. Trouble with that is it would probably take quite a bit of oil(maybe 1/2 pt) to back up and some should also leak from thew prop area, too.
Check the drive oil level in the reservoir and in the drive
jtybt15,
There's very little oil missing from the remote bottle. Less than half a finger width as a poor visual for you. None is coming from the outdrive itself or prop areas. I'll chalk this up to I screwed up and will pay for it to be fixed.
Ken
